Need help '04 5.4 3v running lean
Old Jan 23, 2017 | 09:32 PM
DANA60's Avatar
DANA60
I've got an '04 f150 5.4 3v that I was told needed new cats and had code p0420. I replaced all 4 cats and put 4 new o2 sensors on. When I first test drove the truck it ran fine until underload in overdrive, then it would buck and start to miss. From here I watched the live data on my scan tool and it looked my MAF wasn't reading the right lbs/s so I replaced that along with the dirty air filter and fuel filter. On my next test drive the truck responded the same way. I can get the truck to throw a pending code of p0171 and also just got a p0302 so it seems my problem is on the passenger side. My short term fuel trims look good at idle and I sprayed looking for any vacuum leaks but found nothing. My last thoughts were possibly a bad injector, bad plugs or coil pack. Any help is greatly appreciated.
Old Jan 24, 2017 | 05:33 PM
projectSHO89's Avatar
projectSHO89
Gee, what a huge amount of pi$$ed away money on wasted parts. You'd have been better off taking it somewhere for a professional diagnosis in the first place.
You do NOT have an engine running lean, you have an engine that is running rich plus has a misfire. Spraying and listening doesn't work, the computer is too fast.
Fix the misfire first.
Old Jan 24, 2017 | 09:19 PM
DANA60's Avatar
DANA60
The truck was taken to a shop nad diagnosed as needing new cats, I confirmed with temp test showing faulty cats. No need to reply with comments like that it helps no one in the end.
Old Jan 24, 2017 | 09:20 PM
DANA60's Avatar
DANA60
I spray and watch fuel trims in live data at the same time as well as graph it
Old Jan 25, 2017 | 11:42 AM
R&T Babich's Avatar
R&T Babich
Zero in on the #2 misfire first.
Are all cylinders misfiring or just #2?
If just #2, easy test for bad COP is swap it with #1.
The coil is probably good, how are the boot/spring?
How many miles since the boots/springs been changed?
Are you getting 12v thru the coil and injector lines to the PCM.
The PCM is going to ground the 12v power for the coils and injectors so the 12v should go all the way to the PCM connector input pins.
Old Jan 25, 2017 | 12:58 PM
projectSHO89
Then you need to state explicitly what you did, not leaving the subject open to interpretation.
The quality of the responses you get are going to be directly proportional to the quality of the information you provide. If you provide lousy or incomplete information, guess what type of response you're likely to get....
Old Jan 27, 2017 | 11:27 AM
70f100longbed's Avatar
70f100longbed
A misfire can cause lean codes. The O2 sensor picks up the unburned oxygen and the PCM interprets that as running lean. O2 sensors read oxygen, not fuel. Lean=leftover oxygen in the exhaust that didnt get burned, rich=no oxygen in the exhaust from total burn.
Fordmom530
Modular V8 (4.6L, 5.4L)
Mar 22, 2015 08:30 PM
coloradoinsane
2004 - 2008 F150
21
Sep 19, 2014 09:15 PM
golieth
2004 - 2008 F150
May 9, 2008 09:41 PM
bonczekra
1997 - 2003 F150
Dec 4, 2006 10:53 PM
