Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Misfire
Old Nov 4, 2016 | 11:43 AM
butch h's Avatar
butch h
Misfire
Has anyone experienced a misfire (#2 cyl.) that doesn't put the CEL on, but does put up a pending P0302 code? Plugs and COP,s all have been replaced with no change.
Thanks, Butch
Old Nov 5, 2016 | 05:30 PM
scott91370's Avatar
scott91370
I don't know like if a bad fuel injector would cause this but someone smarter than me will tell us.
Old Nov 5, 2016 | 07:55 PM
projectSHO89's Avatar
projectSHO89
"Pending" codes do NOT turn on the MIL.
Old Nov 6, 2016 | 03:45 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Butch - Is this a 2.3L or 3.0L? We see a good number of PCMs fail on these vehicles but they will usually throw the P0352 instead of the P0302. The P0352 points to a bad PCM due to damage by a faulty ignition coil. Also, what type of coils did you install?
Here's a link to our blog on why we recommend buying Motorcraft coils from a reputable seller/dealer -
https://circuitboardmedics.com/blog/...gnition-coils/
If it ends up being the PCM, we can help! Here's a link to our repair service as well -
https://circuitboardmedics.com/ford-escape-pcm-repair/
Thanks, Butch
Old Nov 7, 2016 | 12:35 PM
butch h's Avatar
butch h
I'm sorry, I wasn't thinking on my original post. This is a '02 with the 3.0 V-6 engine. The replacement parts are from Ford. As I said, the CEL isn't on, but a P0302 is in the pending section of my scanner. I have heard of this being an ECM problem, and naturally, I'm looking for a less drastic solution.
Thanks, Butch
Old Nov 7, 2016 | 02:21 PM
70f100longbed's Avatar
70f100longbed
Do a compression test. I have seen some burnt exhaust valves on these.
Old Nov 7, 2016 | 11:38 PM
bmuhlbach's Avatar
bmuhlbach
I had a pending code, mine would run idle fine if you drove at a constant speed it had a miss it was a coil pack on mine.
Ranger Bob
1983 - 2012 Ranger & B-Series
Oct 25, 2017 01:37 PM
BigBlkEX
Jun 18, 2014 11:33 AM
TheGageinator
2004 - 2008 F150
Mar 7, 2014 12:14 PM
Mike-11
Jan 29, 2011 01:53 AM
Magicman97
Modular V8 (4.6L, 5.4L)
Sep 18, 2007 09:22 PM
