Battery light
Old Dec 4, 2007 | 11:50 AM
Yukon's Avatar
Yukon
Just shy of 150k.
Old Dec 4, 2007 | 12:11 PM
SpringerPop's Avatar
SpringerPop
It's time to borrow a good volt meter if you don't already have your own, and read the voltage across the batteries when the engine's running at about 1800 rpm.
Voltage should read very close to 14.4 volts DC, which is the "set point" for them. You need to be able to accurately read down to tenths of volts for this. If you really are at 12-13, as you earlier noted, you've got a true alternator problem!
Pop
Old Dec 4, 2007 | 12:26 PM
just another truck's Avatar
just another truck
Originally Posted by Yukon
just another truck-can you explain to me how the wire will help me of the alt is bad?
It will not, but it allows the battery to be charged more directly.
Old Dec 4, 2007 | 12:48 PM
Yukon's Avatar
Yukon
Springer, I do have a good Fluke voltmeter and will check the terminals like you said. I'll let you know what I come up with. My 12-13 volts was just looking at the gauge.
Old Dec 4, 2007 | 01:25 PM
just another truck
where are you at in Michigan, if your close by, swing by, will put a load on it. Otherwise, cheat, hit Autozone up, they will test for free.
Old Dec 4, 2007 | 01:35 PM
Yukon's Avatar
Yukon
Thanks for the offer but I am near Holland, I was also thinking about stopping at an AutoZone or this one man auto electric shop. Do I have to remove it at Autozone or will they test in the truck?
Old Dec 4, 2007 | 01:43 PM
just another truck
They test it right on the truck. Also, do the votltage test from the back pin on the alternator to ground, find out what the voltage is. Like Pop is saying, it is a set voltage.
Old Dec 4, 2007 | 08:23 PM
Yukon's Avatar
Yukon
Tested at home 12.62v with truck off and 12.30v with truck at 1800 rpm. I will have to try to get to Autozone tomorrow.
From these measurements does it sound pretty definate a alternator?
Old Dec 4, 2007 | 09:09 PM
SpringerPop
Yes. With no current drain at all, the battery is reading about par.
Add the small amount of current drain that a running vehicle typically draws, and it would drop a bit if there was no charging action.
If the alternator has field current flowing TO it, and nothing coming OUT of it, you may have a defective alternator. But first, you must now determine if the field has current available. It's a FUSED circuit, so this may be as simple as a blown fuse, too.
Check for voltage on pin "A" (OR/LB). If none, start checking for a blown field current fuse. It's a 10 amp, and I think it's #6 in the under-hood fuse and relay panel.
Pop
Old Dec 4, 2007 | 10:54 PM
briank's Avatar
briank
When my battery light started flickering had the batteries tested. 1 was bad and the other was fine. Replaced the one. About a day later started back. I drove it like that for about a week. While I was on my way pulling my trailer with a car on it, it started not to charge and then would. Of course I was running at night. I made it about 100 miles before I had to stop and wait for the parts store to open up. Replace it and then a week later had to replace the other battery. New I should have changed alt before starting on the trip.
Old Dec 5, 2007 | 09:47 PM
mangoIN's Avatar
mangoIN
I just posted on another string I had the same issue, replaced top altenator in March, I had a bad batt in july replaced them both then just the other day Batt light flickers at low rpm's ended up being the lower alternator. One other item worth mentioning when the issue with my second alt started it just died going down the road, had to jump it and no time to trouble shoot so I took it by the stealer, they called and said that it was the pigtail from upper alt to voltage regulator, I had them fix it and when I picked it up I asked for the part. I did a continuity test and it failed, stripped the wires and there was a broken wire in there. This was not my ultimate issue but I do think that is why it died going down the road in the midst of my lower alt weakening.
Old Dec 5, 2007 | 09:54 PM
mangoIN's Avatar
mangoIN
SpringerPop, when you say test voltage accross Batteries, what do you mean + on one and - on the other??? I was trying to test output on one alt vs the other and since they are in series I didnt feel I was getting accurate read. Wish I woud have found this post a month ago. I am glad they are easy to remove and test individually!
Old Dec 5, 2007 | 10:49 PM
  #28
cangim's Avatar
cangim
[QUOTE=Izzy351]hhmmm... Sounds like a weak alternator to me. Mine came on and stayed on. Replaced with a new one (not reman) back in June and it has been fine so far. There is a place to get some really heavy duty alts, which I wish I knew about before I bought mine from AZ for almost $200. For not a lot more, I could've had a 160A heavy duty, or even a REALLY stout 200A...
http://www.alternatorparts.com/Ford_7.3_Power_Stroke_Diesel.htm[/QUOTE]
This is the place i bought my replacement from, have a few pic in gallery if you want to look. I am completely happy with it. I bought the 140AHD version. I also added some 4awg wire from the output to the driver side battery.
Old Dec 6, 2007 | 01:35 PM
  #29
Yukon's Avatar
Yukon
Had alt. tested, bad. New one installed-light gone off dash and battery gauge showing more volts than before. I was pretty much running on batteries the last two days, my volts were down to 11.5. Problem gone.
Thanks for all your help!
Old Dec 6, 2007 | 01:39 PM
  #30
Izzy351's Avatar
Izzy351
Good. The clue should've been when you saw only 12.3V with the truck at 1800 RPM... You should see around 14V like that.
