Blown Sparkplug
Old Jan 19, 2008 | 10:38 PM
OVER_KILL's Avatar
OVER_KILL
Post
Steven,
I would definately consider doing all 8 inserts (TimeSert or BlownoutSparkPlug.com). It's better to be safe than sorry.
There's many threads about someone doing 1 insert and finding out later on, that there's another one thats loose, ready to pop out, or worse, it does pop out. The owners thought that this could never happen again.
Just do a search.
Good luck.
Randy
Old Jan 19, 2008 | 11:11 PM
ronk1969's Avatar
ronk1969
i would think that if you do all 8 you might as well try and find another engine and put in it.
Old Jan 19, 2008 | 11:39 PM
hallam's Avatar
hallam
No problems with inserts...
Originally Posted by Steven in Ct.
Thanks, no one in my immediate area wanted to do the insert repair. However, and this surprised me, the Ford dealer suggested it after I balked at the 3K+ repair bill for a new head. It did wind up costing me about 600 dollars, which is way too much. The plan right now is to get an insert kit myself and go through the rest of the plugs in the spring. Thanks for your thoughts.
Steve
I'm with Anfo on this one... I wouldn't do all 8 plugs. Just make sure all of your plugs are seated and torqued properly.
I had the same thing happen to me (#8 plug). One Heli Coil plug kit and an hour later it was done. Heli Coil plug kits pretty much guarantee you never loose an insert or the threads - if inserted correctly.
BTW - I have over 350,000 miles on my '97.
Old Jan 20, 2008 | 10:10 AM
thecardoc's Avatar
thecardoc
You might take a look a NAPA part # 600-3248 Plug repair .
It is a do it your self repair that works like a oil pan plug where you put in a repair plug and from then on you leave the outer part in and only remove the center part for service
Old Jan 20, 2008 | 07:03 PM
Gage2502's Avatar
Gage2502
What causes this problem?
And why wont Ford do a recall?
~Gage~
Old Feb 18, 2008 | 05:38 PM
ripsterone's Avatar
ripsterone
I have a 98 and it has happen twice! But lucky me they both went right back in without any problems. I have a guy who is selling a 99 for $2000 that won't start. He said he left the local hardware store and it started making a load rattle sound and then die. I look at the motor and could see any expelled plugs without getting to deep in it.
Was wondering if anyone had there truck die completely after it happen? I was able to drive mine to a auto store both times.
Old Mar 30, 2008 | 03:09 PM
crashyoung's Avatar
crashyoung
Heli-coil is a well known product here in Michigan where corrosion destroys many things!
I personally have had many things with heli-coil inserts installed, and they have held up very well. Mostly it is the aluminum heads that failed to over torquing the plugs, but even cast iron fails for the same reason.
I have installed the inserts myself, and I have had others do them, and it is a straight forward procedure. They do last, and the results are stronger than the original threads in aluminum. I am not a profesional mechanic, but I do have a little experience, so I do not hesitate to recommend them.
Pulling the head and doing the work is a bit of a pain, but it usually is much easier than a motor swap. Funny thing is, I have a head with a broken plug in it right now I am working on removing! I will use the heat and vibration system to remove it, hopefully I don't need to pull a head!
BTW, tighten till stripped and back off a quarter turn, is just a joke!
Old Mar 30, 2008 | 03:24 PM
operator414's Avatar
operator414
This is the things that make me scared to do it on my own, I have changed a 1000 plugs in my days, but never on my truck 5.4, and I dont think I want to do it, if I some other shop do it at least they would be responsible for any damages!
Old Apr 1, 2008 | 07:07 PM
crashyoung's Avatar
crashyoung
Plug Fear
Hey 414,
Don't sweat it, just be sure the engine is warmed up first. That was my problem, I didn't warm up the engine first... Oh well, guess I shouldn't try rushing the job...
Old Apr 2, 2008 | 10:45 PM
Gevans17's Avatar
Gevans17
~Gage~
<!-- / message --><!-- controls -->
Ford causes this problem and they wont do a recall because they refuse to admit there is a problem. Now Ford has a problem, as their market share is dropping. Maybe if they took better care of their loyal customers, we would buy more Fords...but dont hold your breath.
Old Apr 3, 2008 | 08:25 PM
operator414
I heard that you should do this on a cold motor, because when its hot it will take the threads with the plug, I have heard this fro a cpl of people?
Old Apr 3, 2008 | 08:46 PM
pdqford's Avatar
pdqford
IIRC, the motor needs to be cool if you have Aluminum Heads.
Old Apr 3, 2008 | 09:52 PM
  #28
crashyoung's Avatar
crashyoung
Hey all!
After several bad attempts to extract the shell of the broken plug, I finally got it out!
I broke 2 Craftsman, 3/8 inch 3/8 drive sockets on my easy out!
I then bought a tap socket from snap-on which is heavy duty and 1/2 inch drive.
Using just my 1/2 inch ratchet handle, I was able to extract the shell of the plug after running the engine 20 minutes to warm it up a bit.
All I can say is, I was releaved!
Looks good once again, for my inexpensive truck restoration!
Old Apr 3, 2008 | 10:57 PM
  #29
MisterCMK's Avatar
MisterCMK
NEVER change plugs on a vehicle with an aluminum head when it is warm or hot. It must be COLD.
Norsegod127
1983 - 2012 Ranger & B-Series
17
Feb 12, 2016 07:22 AM
SDHauler
Oct 20, 2015 05:25 AM
ctarborist
May 10, 2015 09:30 AM
GrayRanger4x4
Georgia Chapter
Aug 17, 2006 05:35 PM
