Restore
Old Oct 14, 2001 | 05:07 PM
cjo's Avatar
cjo
Restore
Anyone here ever use Restore with good results(the stuff you poor in your oil, supposed to fill scratches in the cylinder walls etc etc.) I was thinking about buying some for my truck but I dont want to waste $7.00.
Thanks
Old Oct 14, 2001 | 08:24 PM
TallPaul's Avatar
TallPaul
Restore
What condition/problem are you having with your truck that makes you want to try this stuff? Give us details along with year, miles, etc.
Old Oct 14, 2001 | 10:19 PM
kspilkinton's Avatar
kspilkinton
Restore
[font size="1" color="#FF0000"]LAST EDITED ON 14-Oct-01 AT 11:21 PM (EST)[/font][p]Used the stuff since the 200K mile mark. I had two cylinders with low compression readings (100 lbs while the others were around 135). I put the stuff in to test the principle. If it worked, I just saved myself a rebuild project. If it didn't I just wasted the $8.84. After 200 miles (about 4 days worth of driving) I rechecked the readings. All cylinders were at or above 140 lbs. I also noticed the truck idled smoother and ran better.
Not trying to sell you on the stuff, but it seemd to work for me. I also change the oil at least every 4,000 miles and add the stuff every change. I've changed the oil without the Restore and noticed a performance difference within a week. The compression reading dropped back to what they were before the Restore was ever added.
Since the 300 is close in size to a small block, I use the 8 cyl size. Figure the stuff has a lot of surface area to cover in the long stroke block.
Kerry
"Ran fine for me, must be the operator..." -Dad
'82 F-150 4X4;
300-6; MSD Blaster 2 Coil;
245,000 original miles and still rolling
Old Oct 15, 2001 | 12:34 PM
cjo's Avatar
cjo
Restore
Tallpaul, nothing is really going wrong with the engine just thought i might be able to restore a little lost horsepower that comes with the age and mileage. The trucks an 87 f-150 it has 190k miles on it. Thanks for the replys.
Old Oct 15, 2001 | 07:05 PM
Hausladen's Avatar
Hausladen
Restore
I also used the stuff and it helped, i can really notice the difference since i quit using it.
Old Oct 15, 2001 | 09:46 PM
DantheMan's Avatar
DantheMan
Restore
johnmel59
20
Jan 2, 2014 09:02 PM
n9lhm
13
Jan 19, 2010 04:08 PM
Cruiseomatic
May 26, 2005 02:04 PM
papapetes45
1947 and Older Ford Trucks
Jun 24, 2003 06:32 PM
Flatbed Ford
Oct 21, 2002 04:22 AM
