Sponsored by: Auxito
Service Engine Soon Light
Old Mar 24, 2002 | 02:03 PM
hitchs's Avatar
hitchs
NEED INFO:
I just replaced my 4.6 Engine in my 1999 Ford 150. The old one needed a new head etc. etc. so I found a brand new dynotested 2001 engine (4.6 also) and had it installed. It drove fine for the first 100 km then my "service engine soon" light came on. I've cleared the codes twice but it keeps coming back on. I called the shop that installed the new engine and they told me "not to worry about it" the computer is just learning the new engine settings and at my 1000 km oil change they'll clear the codes and check it over.
Does this sound right to anyone ???? What's the chance that this situation will correct itself ? I'm worried maybe the computers not compatible with the new engine etc. or that I'm going to damage something in the next 1000 kms before it's checked.
ANY ADVICE.
Old Mar 24, 2002 | 09:21 PM
z 97ford1's Avatar
z 97ford1
Go buy a OBD II dianostic code reader for your year truck. It is easy to use and will tell you what the check engine light is about. Autoxray makes a good unit and is well worth the money you spend. You can buy them at any local auto parts store for about $250. I have one and have already used it.
good luck
Old Mar 24, 2002 | 11:55 PM
nitro94's Avatar
nitro94
If I was the one that installed the engine and you called me with this information I would want you to come back in an let me check the codes and then tell you if it needed attenton now or later. Reading the codes is the only way you can know if it is harmful to the engine.
Old Mar 25, 2002 | 02:51 PM
hitchs's Avatar
hitchs
I took the truck to my local garage and they checked the codes !! It showing up that the Bank 1 UP sensor (o2 sensor) is reading lean. He did some further data flow readings and disconnected the bank 1 o2 sensor to isolate it and it "apparently" appears that there is little or no activity (volt wise) from that 02 sensor.
Says it's probably malfunctioning and neeeds replacing. I priced a new one and their $148.00 cnd. I sure hope that this IS the problem before I order a new one as it's very pricey if he's wrong. I did pull it out and try and clean it up + get the code off it for ordering a new one and it appears that it's "dented" on one side !! Perhaps they banged it when they dropped the new engine in. I"m wondering if hitting it hard enough to dent it could cause it to stop working ?????
Just hate spending money if their wrong.
Any thoughts ??????????
Old Mar 26, 2002 | 11:32 AM
hitchs's Avatar
hitchs
WELL,
I did it, I went out and bought a new 02 sensor and guess what..same problem !!!!!! grrrr
Computer showing "lean" on bank 1 o2 sensor still. Anyone have idea whether or not maybe this new engine is not compatible with my old computer.
My old one was a 99 4.6...this one is a 2001. The problem seems to be intermitant. What's the chance it will correct itself and go away ?
KEN any ideas. What's the ERG and how do yu reset it ???????
HELP - Can't keep going back to shop daily.
Old Mar 27, 2002 | 08:16 PM
hitchs's Avatar
hitchs
Found the problem. When they installed the new engine they broke off one of the wires in the wiring harness to the 02 sensor...so of course it's not getting any readings and sending out a code to the computer. Took it back today and they are replacing the wiring harness.
Thanks, not that too many people responded to my call for help.
Old Mar 27, 2002 | 09:30 PM
LWM97's Avatar
LWM97
metal7654
1997 - 2003 F150
May 22, 2010 12:17 AM
CameronA710
2004 - 2008 F150
Mar 26, 2010 07:59 PM
Islander1
Mar 12, 2008 09:30 AM
2002explorer
Modular V8 (4.6L, 5.4L)
16
Mar 17, 2005 10:37 PM
nex813
1997 - 2003 F150
Mar 14, 2004 01:20 PM
