rearend fluid.
Old Dec 3, 2007 | 08:07 PM
  #46
Skandocious's Avatar
Skandocious
Yes too low. Buy another 2 quarts and fill it until it overflows out the fill hole. As posted about, it should take between 2 and 3 quarts, probably closer to 3. Don't run your truck with only that much oil back there, you could damage it.
Old Feb 19, 2008 | 09:14 PM
  #47
Bern_F150_4x4's Avatar
Bern_F150_4x4
Originally Posted by Matts72
I'm pretty sure you don't want it that full... fill it to 5/8" below the plug or you will blow axle seals... stick your finger in the hole, the first knuckle is pretty close to 5/8", unless you are Yao Ming or Bilbo Baggins...
Seal leaks occurr from clogged vent tubes... Mud, spider nests etc block ventilation which causes a pressure differential and your leak. Mud in the gearlube can help to speed things up. My owners manual says it is full when the oil level is at the bottom of the fill hole.
r-kid
19
Apr 21, 2011 09:39 PM
shark1979
35
Nov 10, 2010 10:02 AM
Auburn983
Feb 21, 2010 12:37 AM
kupiec20
Jul 24, 2009 08:05 PM
