oil level in hpop?
on
Not really true..Just remove the fill screw on top of the housing and suck out the dirty oil... Again, i use a http://www.liquivac.com/index.php?a=1
I changed mine last week. used a Outboard lower unit oil change pump. about $15 at your local marine store. The oil I removed was not even close to be as clean as the engine oil. Don't over fill the resevoir cause it will just go into the oil pan. I also added some Lucas oil treatment to the resevoir. was really easy and only took about 15 minutes. I would suck out as much as I could and then refill the res. run the motor after for about 10 minutes and then repeat the same process 3 times.
Make sure you replace the plug when you go to start the motor or else oil will go everywhere.
on
Do you have to modify the pick-up tube to get to the bottom of the housing?
on
THe old oil will just stay in the hpop when you do a oil change from the engine pan.. there is a check valve in the pump that holds the oil from draining out.. So you are leaving nearly a quart of dirty oil in the oil system if you don't suck it out during your normal oil change.....
I also pump it out and I know it will get cycled when the engine is running, but why mix fresh oil with dirty oil, its not hard to change. You will want to fill the hpop back up or the truck will not start until the LPOP fills it up. I don't think you want to use Lucas oil additive as it makes the oil thicker, I haven't heard of it gumming up the injectors but I don't want to find out.
on
Well, i think he was just generally referring to the pump and not specifically talking about the PUMP.. The reservoir is what you would normal suck out. The fill screw is not in your pic.. It is in the top of the reservoir...
When people started talking about this, I decided to pump the oil out of my HPOP reservoir. This was the first time in 260,000 miles I had even removed the plug there. I sent off a sample to a lab to have it anaylized. I won't be wasting my time doing that again. The oil flows through there well enough, so 15 qts at a time is good for me.
You're not wrong. Oil from the pan gets pumped through the high pressure oil system, then returned to the pan. If you decide to suck a quart out of the HPOP reservoir during the oil change, that just means you're changing 16 qts of oil instead of 15. Even if you do this, you'll still end up with some of the old oil in the rails, so you won't be able to get all the old oil out, but some like to change as much as they can.
Go to powerstrokehelp.com look in the 7.3L folder and watch the 4 vids on fuel injection tune up. POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners that will get you there. Bill hewitt has a ton of experience with these engines, I know for a fact the oil does not move through the HPOP resevoir very well. You can do an oil change, then run the engine for a week. You will still suck out dirty oil a week later from the HPOP res. Even if the oil sample is good, How long will it stay good? It is so easy to do, why would you not? Better to be safe than to buy injectors sooner
