Help I need a part #
Old Dec 1, 2007 | 04:44 PM
Frank Stahl's Avatar
Frank Stahl
I need a part # for a fuel pressure regulator housing.
I think that is what it is called, it is on the top right hand side of the fuel filter canister.
It has a brass fitting coming from the fuel line.
I think that i need the nut and 0-ring to seal it off.
This is for a 2000 7.3.
I was going to change my fuel filter, and I noticed it was leaking (wet), so I put a wrench on it and it snapped.
I cut the flair off of the line, so I could remove the broken part out of the brass fitting.
So I guess I need the fitting, o-ring, and housing.
Any help would be great, the truck is in my friends shop, need to get it out quick.
Thanks Frank
Old Dec 1, 2007 | 04:51 PM
WonderDonkey's Avatar
WonderDonkey
Fuel Pressure Regulator Repair Kit (contains spring, valve spool & new brass plug)
(Ford) F5TZ-9K061-A (federal emissions; 94-98)
(Ford) F6TZ-9K061-AA (CA emissions; engine serial no. 201681-98)
Fuel Pressure Regulator Spring
(International) 1823643-C1 (federal emissions; 94-98
(International) 1825854-C1 (CA emissions; engine serial no. 201681-98
Fuel Pressure Regulator Screen Kit (Orifice Vent Kit) Includes screened plug, o-ring, check valve
(Ford) F6TZ-9150-AA Screen and o-ring kit
(Ford) F5TZ-9A214-A ??? KIT-VENT ASY -DUAL
(International) 1823658C91 (screen only, doesn’t fit the PSD!!!)
Old Dec 1, 2007 | 04:53 PM
Frank Stahl
How much is it going to cost?
Frank
Old Dec 1, 2007 | 04:57 PM
WonderDonkey
That i am not to sure of my friend, someone who has bought one will chime in though.
Old Dec 1, 2007 | 06:05 PM
IDPisan's Avatar
IDPisan
Here is a fuel preeure regulator
http://www.trademotion.com/partlocat...14072&chapter=
Old Dec 1, 2007 | 06:09 PM
IDPisan's Avatar
IDPisan
I tried using the link and you will have to use the keyword funtion.
186.90 for the fuel pressure regulator, 311.50 MSRP
Old Dec 1, 2007 | 06:11 PM
Frank Stahl
what is the part #
Thanks Frank
franknorman
17
Sep 8, 2016 11:13 PM
chadjones99
Jun 23, 2015 09:36 AM
Bluey Zedoff
29
Mar 29, 2015 09:16 PM
go2guy
Apr 4, 2014 01:27 PM
