injector lines leaking
Old Jun 21, 2015 | 12:12 PM
chadjones99's Avatar
chadjones99
so I need a little help. I have a 1991 F250 I think it is the 7.3 and I know its a non turbo dual tank truck and it seemed to be worse on one tank than the other as it pertains to this leak issue at first. anyway I have had the truck for about a year , and I am not in town much, but last time I was home it started leaking( fuel PS side of the motor ) where the metal injector lines attach to the injectors. I took the 2 that where leaking off and it looked like the O rings on the injectors where just old and starting to split. so I used a regular O ring kit with no luck they still leaked so then I took the plastic cone shaped piece that goes over the top of the injector and put a small brass washer and put on top of it where the injector line screws down as it look as if the cone piece was loose just a hair and need to be pushed down a little more. this seemed to work but then the next two injectors started ,etc my question is has anyone here had to chase this issue. I am thinking that it could be you have to use special size O rings ? vs ones out of a kit or is the cone piece replaceable ? I would think as long as the O ring was snug it would work, also could there be another issue like the return line valve being clogged. just look for what normal for a old injector leak issue. I asked because if the two just started leaking why would the other to start as soon as I fix the first two unless there was a return line issue and the first 2 leaks relieved the pressure enough and now that its fixed the pressure made the next 2 weak lines fail ? or is it normal when these O rings fail for them all to start leaking. Also note its all on the PS of the motor drive side no leaks at all
Old Jun 21, 2015 | 02:44 PM
vfelix702's Avatar
vfelix702
Return lines and caps
Your need a return line kit and use viton o - rings 111 available at McMaster carr. 2 o rings per injector once you start moving the caps around they all start leaking.
Old Jun 21, 2015 | 04:18 PM
chadjones99
cool I found a kit on ebay , lines clamps , return hose , o rings , etc
hey can you help me with belts ? I am not home to look right now its a 1991 diesel 4x4 with AC , vac pump , PS & alt ( info for belt size purposes ) . I broke a belt and it cause the 2nd belt to get thrown off. I was able to get the one belt back on so I had a water pump to get home the day it broke( no PS or alt on way home ) then I ran out of time and parted it. So basically I need to replace both belts. thanks
Old Jun 21, 2015 | 04:28 PM
hturner12's Avatar
hturner12
Any parts store on belts and yes it is a 7.3. I hope you did not buy the return line kit from Pensacola Injecton
Old Jun 21, 2015 | 04:33 PM
chadjones99
Yes I know its a 7.3 being non power stroke. question did ford not use a 6.9 IDI a few years before that and I heard it was the same engine and used a lot of the same parts.. anyway injector O ring kits for 92-94 & 83-91 fords now on the one I bought this list 2 sets one set was for early and late. looking at the picture of the plastic housing mine looked like the late which they also listed a 91 to 94 ??? I was confused because I seen other kits listed 92-94 so is the late 91 kits the same as the 92 to 94 kit ? because it was cheaper. anyway here is a link to what I just ordered check it out and let me know if you think I got the right one. note in the picture as what they show as a "LATE" looked like what I was working one to keep from leaking
http://www.ebay.com/itm/371289287923?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jun 21, 2015 | 04:36 PM
hturner12's Avatar
hturner12
Ford International 7 3L IDI Diesel Injector Installation Kit 91 94 | eBay
You havery the late ones
Old Jun 21, 2015 | 05:10 PM
vfelix702's Avatar
vfelix702
These are the belts I use
Old Jun 21, 2015 | 05:59 PM
chadjones99
does the one that's says A58 does that mean a 58 inch belt if I get another brand ? by the way thanks
Old Jun 21, 2015 | 06:00 PM
hturner12's Avatar
hturner12
o the one that's says A58 does that mean a 58 inch belt if I get another brand ?
Use the numyers below in on the package
Old Jun 21, 2015 | 06:17 PM
chadjones99
1991 ford F250 at 7800 ft above sea level pulling our 31 ft toy hauler RV
slowly !
Old Jun 22, 2015 | 09:43 PM
Macrobb's Avatar
Macrobb
slowly !
Needs more turbo!
Old Jun 23, 2015 | 09:36 AM
chadjones99
non turbo, was just relocating RV down the road. would not want to drive across country with that truck
tweldon
16
Dec 6, 2009 05:22 PM
desert sled
Nov 12, 2007 11:03 PM
geaux tigers
18
Dec 5, 2006 08:59 PM
ALL BOY
Jan 23, 2006 09:11 PM
thechad
Oct 26, 2004 09:09 PM
