Transmission stuck?
Old Dec 3, 2007 | 02:01 PM
DieselCamper01's Avatar
DieselCamper01
Thanks Mark,
I will double check fluid level right away. If all is ok I will keep the fingers crossed for now. All has been ok the rest of this weekend and today so far.
Old Feb 8, 2008 | 08:19 AM
DieselCamper01
Update. I have had this problem with my transmission come up a couple weeks ago again but by putting it in 1st or 2nd gear directly or into reverse. After several attempts it was suddenly fine. Until this morning. Drove the 6 miles to work having to put the tranny in neutral at all stop lights then dropping to 1st gear and working my way up to Drive. As stated previously I am no tranny mechanic but I am 100% convinced that the TC is staying locked in. It gives all the symptoms people talk about when they do the TC lock mod. If you leave it manually locked and come to a stop it will stall. That is exactly what mine is doing. Anyone have any thoughts?
Old Feb 8, 2008 | 08:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Your torque converter is stuck on.
There are several potential causes. Is the OD light flashing? If so, there's a code stored that will give a clue as to what's wrong.
It could be a bad torque converter clutch solenoid. It could be a short in the wire to the solenoid. It could be a stuck valve in the valve body. It could be a bad torque converter, but that's not likely. Usually when the torque converter fails it won't lock.
Old Feb 8, 2008 | 08:44 AM
DieselCamper01
OD light is not blinking. Do you think this is something I can tackle? I am an ok backyard mechanic. I do have a full manual. I do not have anywhere indoors to work on it though. Supposed to be cold and windy this weekend. Highs in the single digits. Lows below zero. Would a local shop be able to easily diagnos this?
Old Feb 8, 2008 | 11:53 AM
DieselCamper01
Bump. Anyone have thoughts on where to start first? What testing/troubleshooting can I do on my own first?
Old Feb 8, 2008 | 12:20 PM
DieselCamper01
OK.Get this. Just went out on lunch, started truck, put in gear, all is fine. WTF? I hate problems that fix themselves!
Old Feb 8, 2008 | 12:56 PM
Mark Kovalsky
Since it fixed itself I'm leaning towards a valve that got a piece of dirt and stuck.
Old Feb 8, 2008 | 01:22 PM
DieselCamper01
Would this be good excuse to use on the wife to get a BTS valve body?
Old Feb 8, 2008 | 02:52 PM
Mark Kovalsky
Sorry, I don't do marraige counseling!
Old Feb 8, 2008 | 02:57 PM
Meatco1's Avatar
Meatco1
Why don't you just give John Wood, or BTS a call, and ask the experts? Either one of those fellows will have a pretty good clue as to whats really up with your trans.
Good luck,
Richard
Old Feb 8, 2008 | 03:15 PM
DieselCamper01
Richard. Great idea. I am giving both you and Mark reps for your help.
Thanks!
Old Feb 8, 2008 | 03:22 PM
Meatco1's Avatar
Meatco1
DieselCamper:
Lord, I hate to act foolish, but I'm at a loss. How does one give "rep points", and how does one view them?
Thanks,
Richard
Old Feb 8, 2008 | 03:28 PM
  #28
PaysonPSD's Avatar
PaysonPSD
Thanks,
Richard
Next to the Post # there is a set of balance scales. Click on that to give rep points to the one who made that post.
You can view your own rep points by clicking on CP USER at the top of a thread.
Old Feb 8, 2008 | 04:01 PM
  #29
Meatco1's Avatar
Meatco1
Thank you Payson.
Been a member her for over a year (I think), and never had a clue.
There's certainly been times I would have liked to award these points to other members.
Thanks again,
Richard
Old Feb 8, 2008 | 04:31 PM
  #30
PaysonPSD's Avatar
PaysonPSD
Thank you Payson.
Thanks again,
Richard
I'm glad you got it figured out.
