Sponsored by: Real Truck
Super Duty Electrical Problems
Old Dec 2, 2007 | 12:23 PM
ageel's Avatar
ageel
I don't have the experience of the users who have tried to help so far but wouldn't the door ajar switch being stuck cause these type of problems?
Old Dec 2, 2007 | 12:29 PM
NJ Poolman's Avatar
NJ Poolman
Hi, I only have the alarm that was installed by the factory, nothing else.
I will check that gem module ( Thank you ) right now.
I can't believe this. Just from changing a battery. I have never seen this before. Just my luck !!
Thank you for your help. NJ Poolman
Old Dec 2, 2007 | 12:30 PM
NJ Poolman's Avatar
NJ Poolman
by the way, do you know what this code means ? 9352 ?
Old Dec 2, 2007 | 12:31 PM
99f350sd's Avatar
99f350sd
The steering wheel lock is manual..door sw will cause lights but not the other stuff..
Old Dec 2, 2007 | 12:44 PM
ageel's Avatar
ageel
Hi 99f350sd
I'm just trying to understand this but if the truck thinks the door is open all the time wouldn't that cause most of the OP's problems. Our radio only turns off after the door is opened with the key off.
Old Dec 2, 2007 | 12:46 PM
99f350sd's Avatar
99f350sd
Not for 02 I don't think..My 05 yes
Old Dec 2, 2007 | 12:52 PM
ageel's Avatar
ageel
Our 03 at work is like that. We had some of these problems when the switch stuck but not having an alarm I know nothing about that system Just my .02 worth.
99f350sd's Avatar
99f350sd
I wonder if he has delayed entry option?? As AGEEL said maybe you should check for a bad door sw. I guess the fix is to soak it with wd40. Open the door and spray it in the lower part of the latch. I never heard of this causing so many issues but give it a try I guess.
Old Dec 2, 2007 | 01:19 PM
NJ Poolman's Avatar
NJ Poolman
Hey Guys,
Before all this happened, My radio and windows too only shut off after I turned off the ignition and open the drivers door.
One thing I just noticed was that the two wires that feed both back doors for the pin switch are both hot. I got power from each wire regardless of having the circuit open or closed. is this normal ? If so, why ?
Old Dec 2, 2007 | 05:52 PM
99f350sd's Avatar
99f350sd
Lube the front door locks
Old Dec 5, 2007 | 01:04 PM
NJ Poolman's Avatar
NJ Poolman
Hi all,
Well it looks like it was the VSM. ( Vehicle Security Module ) My new one will be in on Thursday. $128.00 . I will keep ya posted and thanks again for all your ideas !! NJ Poolman
Old Aug 14, 2010 | 12:13 PM
l_anthony's Avatar
l_anthony
This is an old thread but? The Ford dealer has my truck. They unlocked the door and the alarm went off and the key locks started to cycle continuously? They had to unhook the battery? They don't know? The guy I am actually buying it from from said this happened before, so the replaced the VSM. He said after that it happened one more time and it never happened again until now? He said he will order another one but does this hint of other electrical problems?
Thanks,
L_Anthony
COMTNMAN
Mar 5, 2014 10:58 AM
COMTNMAN
Mar 4, 2014 02:54 PM
hellmary
Aug 10, 2013 06:23 AM
