Sponsored by: Real Truck
Super Duty Electrical Problems
Old Dec 1, 2007 | 02:02 PM
NJ Poolman's Avatar
NJ Poolman
Hello,
I was wondering if someone might be able to help me in regards to an electrical problem I am having with my2002 Super Duty F250.
I had to change out the battery and when I was finished I noticed that my door locks do not work, The open door light on the dash stays lit even though the doors are closed, The interior light does not come on when the door is open , the radio does not power down even after the ignition is turned off and the door is open and the security system does not work. I checked all the fuses and I found nothing wrong with them. Can someone help me? I am stumped.
Thank you, NJ Poolman
Old Dec 1, 2007 | 02:25 PM
fordfaninIL.'s Avatar
fordfaninIL.
It sounds like you have a bad or broken ground wire. Check around the battery for a possible broken wire or even one that you might have forgotten to hook up when replacing the battery. If you can not find any, take some time and clean all the ground wires that you can find. Over time grounds corrode and get weak, and by replacing the battery you are asking them to work as if they were new. This can lead to some funny stuff happening.
Old Dec 1, 2007 | 02:59 PM
NJ Poolman's Avatar
NJ Poolman
SD Electrical Problems
Hello,
Thank you for the info.
All ground wires are attached and the terminals are clean.
The truck runs fine except for the problems that just ac cured.
I have never come across such a weird problem in 20 yrs of being my own mechanic. Thanks again for your help !!
NJ Poolman
Old Dec 1, 2007 | 07:09 PM
JOE-M's Avatar
JOE-M
I think I'd uhook those batteries again and let it sit for a couple of hours. Then make sure the key is out of the switch and hook them back up and maybe everything will reset.
Joe
Old Dec 1, 2007 | 08:39 PM
F350-6's Avatar
F350-6
Don't forget to check the other end(s) of the ground cable. You will sometimes get corrosion on the block.
Old Dec 2, 2007 | 06:56 AM
chuck06250's Avatar
chuck06250
Except for the door locks, it sounds like you may have a bad door (pin) switch.
Old Dec 2, 2007 | 07:02 AM
NJ Poolman's Avatar
NJ Poolman
Hi,
Thank you for your answer.
I also found these issues last night.
I had to change out the battery and when I was finished I noticed that my door locks do not work, The open door light on the dash stays lit even though the doors are closed, The interior light does not come on when the door is open , the radio does not power down even after the ignition is turned off and the door is opened and the security system does not work. Even after I remove the key and open the door all the power windows still work. Also the lock for the steering wheel does not engage I checked all the fuses and I found nothing wrong with them, all ground wires are clean and attached. Can someone help me? I am stumped.
Old Dec 2, 2007 | 08:38 AM
NJ Poolman's Avatar
NJ Poolman
I just got two DTC codes and they are / D262 and D950.
Can anyone help me with these codes?
Old Dec 2, 2007 | 09:00 AM
99f350sd's Avatar
99f350sd
Have you removed the battery terminals again. Wait a awhile then reattach the terminals. You have a gem module that has freaked out. I would touch the terminals together for a minute to drain off any excess stray voltage.. You may have fried something but it would be rare..
Dick
Old Dec 2, 2007 | 09:11 AM
NJ Poolman's Avatar
NJ Poolman
Thanks Dick I will go try this now !!
Old Dec 2, 2007 | 11:33 AM
NJ Poolman's Avatar
NJ Poolman
Hi Dick,
I gave it a shot but nothing has changed. Thanks for the tip !!
Old Dec 2, 2007 | 12:01 PM
99f350sd's Avatar
99f350sd
Certainly lookfor bad grounds near the battery cables ..sure you didn't hook up the battery wrong for a second? The gem module is causing the issue's because it controls all the things you are having trouble with..Many times as said earlier the problem has been a ground or water leaking down getting on the gem module. what exactly did you do to cause these problems?
Old Dec 2, 2007 | 12:03 PM
NJ Poolman's Avatar
NJ Poolman
I just changed the battery.
Old Dec 2, 2007 | 12:06 PM
NJ Poolman's Avatar
NJ Poolman
Please don't take this wrong I mean no disrespect, but as for hooking up the battery wrong, I am not a novice mechanic and have many years behind me in this field.
Old Dec 2, 2007 | 12:13 PM
99f350sd's Avatar
99f350sd
Well you are assured that that is what caused your problem to show up. You may have had a weak ground and now it showed its face or the initial spark surge when you connected the battery caused a weak electronic circut to go bad. Did you check fuses under the hood? Did you check the ground wires to the right of the steering column if you take the panel off and look up. the gem module is behind the fuse box. Wiggle all wires to see if you can get something to go back to normal. Do you have any accessories like remote start, alarm etc?
