Washer fluid everywhere
Old Dec 1, 2007 | 09:17 AM
jesterdog's Avatar
jesterdog
Hey guys! I'm new here. I just bought an '01 Excursion V-10 Tuesday (traded my '99 Yukon). I tow a TT and wanted a bigger truck.
I'm working through a couple of little problems. I need to replace 4 door lock actuators. I see CUINAK's procedure. I'll get to that as soon as possible.
There is one more issue that has stumped me. I was trying out the rear window washer and nothing was coming out. I kept trying it and trying it, and nothing. So as I'm walking around the truck, I see blue washer fluid leaking out under the passenger side running board and a big puddle on the ground. Washer pump appears to be working good! I crawled under there but I don't see the washer fluid hose. I can't locate the leak. It appears to originate at the passenger rear door and is above the running board. Looks like it's in the body panel. I don't know.
Has anybody seen this problem before? Any ideas?
I appreciate any help.
V-10's rock!
Old Dec 1, 2007 | 01:03 PM
1's Avatar
I believe they run above the headliner in the back! Make sure your not soaking your headliner!
Old Dec 1, 2007 | 01:09 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
jesterdog,
Pull back the FRONT passenger carpet up against the outside of the truck...upper corner...not much needed to pull back...you will see a little "T" or "Y" fitting and a rubber hose...it is likely APART...put it together and you 'should' have function returned...I had this last year...it seems common...I thought about a zip tie...but figured if there was an ice block in the line...having a pressure 'release' would be good...
I'd check the inside by the passenger first...but 1 is right...rear has one too...I was lucky...only the passenger one was open on mine...if yours needs back too...check out post #7 in this thread...afreemanmd did an EXCELLENT job of describing what is needed!
https://www.ford-trucks.com/forums/6...-no-spary.html
Oh yeah...CONGRATS on the EX!...and welcome to FTE...
joe (aka crappie!...I just replied to one of your posts over on RV.net!!!)...
Ex03AK
Oct 12, 2022 04:25 PM
steinernm
Jun 3, 2020 09:25 AM
BigBlackEX
Apr 8, 2020 04:58 PM
Mojave922
May 30, 2016 04:34 PM
kml
Dec 21, 2010 04:16 PM
