Modular V10 (6.8l)
99' V10
Old Dec 24, 2007 | 10:12 PM
irishkev's Avatar
irishkev
Originally Posted by msbweiland
Pull the oil filler off and see if there is any snot. It'll tell you if it's burning water or not.
not trying to hijack thread but, what do you mean by "burning water"? i've been losing water and have a little evidence of it on the filler plug. what does this indicate? am i looking at a major expense?
Old Dec 26, 2007 | 04:06 PM
bkaser90's Avatar
bkaser90
I'm new on here and am gonna continue this hijack a bit. I have a '98 E-350 V-10 Club Wagon and I get the same thing on my oil filler cap. Am I correct to assume that this is the same engine as the '99 F-series?
Old Dec 26, 2007 | 09:50 PM
msbweiland's Avatar
msbweiland
You'll see a coating of slime on the filler cap and inside the filler tube. It usually indicates water in the basement. Could be condensation or coolant. If you're losing water, it has to be going somewhere. (Sorry to say) Coolant doesn't just disappear. That is a great way to check out a used car if you happen to be shopping. Most dealers/owners aren't smart enough to clean it. It'll save you A LOT of $.
You should be able to put a pressure tester on the cooling system and see if the pressure bleeds off, check it hot and cold with the engine off. You can also use the tester and see if the cooling system builds pressure too fast (usually indicates a bad head gasket) while running.
I had some condensation in my 99 V10 when I bought it. I changed the oil and drove it hard for about 100 miles. Got rid of any sign of water in the oil and is doing fine now.
Old Dec 29, 2007 | 11:19 PM
irishkev's Avatar
irishkev
well, head is coming off tomorrow. water coming out of exhaust and my coolant smells like gas. had the slime on the oil filler area. now it's got a lifter/ valve rattle that is awful. never overheated-- was losing water gradually until yesterday when all of the other stuff went wrong
Old Dec 30, 2007 | 09:14 AM
BareBones's Avatar
BareBones
I wonder if maybe we should start another thread on this "snot" issue. My 2005 runs perfectly, but the inside of the oil filler cap does show an abundance of a light tan "snotty" substance when I use dino, though I don't believe it does when I use synthetic.
Why do you believe this is water related?
Old Dec 30, 2007 | 01:31 PM
msbweiland's Avatar
msbweiland
Yes. In my experience any sort of snot substance is water related. Could be condensation, more than likely coolant.
Old Dec 30, 2007 | 04:03 PM
BareBones's Avatar
BareBones
Agreed. I'll start one now and get out of this thread. Thanks.
Old Dec 30, 2007 | 05:28 PM
anfo's Avatar
anfo
I had a 99 and I only had the "snot" was I was making alot of short trips around town. After a good run on the freeway it would clear up, I think alot of people see this one thing and think to much of it.
Old Dec 30, 2007 | 05:54 PM
BareBones's Avatar
BareBones
I started a thread on it in the SuperDuty forum. One response indicated he see's it on other makes of gassers too. He also doesn't think its a problem....
Old Dec 30, 2007 | 06:01 PM
msbweiland's Avatar
msbweiland
From my experience with my fleet trucks it's a sign of problems yet to come. Without a doubt the rigs that have the snot eventually end up with a bad head gasket/cracked head. Mostly in the diesels.
The freeway trips get the oil hot enough to burn the water out, that's why the snot goes away. I wouldn't tare a motor apart just because I found snot in the filler, I just use it to make me aware of problems that might be coming.
rc.chris
Jul 24, 2012 04:51 PM
BigBully
Modular V10 (6.8l)
Feb 7, 2012 05:52 PM
dybeepvw
Modular V10 (6.8l)
Nov 28, 2011 05:26 PM
F250saleen
Modular V10 (6.8l)
Feb 14, 2011 01:41 PM
jhemr
Modular V10 (6.8l)
Jun 22, 2004 05:22 AM
