Sponsored by: Real Truck
'99 v10
Old Jul 21, 2012 | 07:40 PM
rc.chris's Avatar
rc.chris
'99 v10
I am looking at a '99 f250 4x4 with the v10. It has 162000 on it. Have there been any issues with the olded v10's?
Old Jul 22, 2012 | 10:34 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Bump to the top for more people to see this.
Old Jul 22, 2012 | 11:35 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
First I would post in the V10 forum, just scroll on down on the main page. The 99 was the only year that the SD had the lower HP V10 before they went to the PI heads. It was also the worst year for plugs blowing out because of the way they were installed at the factory. If the truck has 3.73 rear end gears it will be lacking in performance compared to one that has 4.10 or 4.30 gears that are a better match for the V10. If it was well maintained it should still be a good motor with 160K on it.
Denny
Old Jul 22, 2012 | 11:45 AM
rc.chris's Avatar
rc.chris
Thanks for the info.
Old Jul 22, 2012 | 01:56 PM
FordGuy85's Avatar
FordGuy85
What are you planning on doing with the truck. What gears are in it? Is the truck in good shape?
Old Jul 23, 2012 | 05:40 AM
rc.chris's Avatar
rc.chris
Mainly a daily driver, and pulling my boat. Hauling it locally and once a year about 500 miles, its about 8000to lbs.
Old Jul 23, 2012 | 10:55 AM
DarrellinCeres's Avatar
DarrellinCeres
I have the 99 SD SC 4x4 with the V10 and it is my daily driver as well. I'm at almost 270K on th OD. There are some on this site turning 300-400K on their V10s.
I test drove one that had the 5.4 and I felt it was way under powered for such a big truck. The V10 pulls the 250 like the 5.4 pulls a 150. Biggest issue is keep up on the maintenance and if you change the plugs yourself or have someone do them make sure that a torque wrench is used and there shouldn't be any problem.
Rear end gearing is a big thing on how these trucks feel as well. Brings the RPMs up to wher ethe V10 likes it. I have the 430LS with 285/75/15 tires. It tows good and rides good.
As also stated the 99 is the lowest HP of the V10. The head and intake design restricts air flow but with the addition of a 5-star tune and I don't notice it.
Old Jul 23, 2012 | 12:20 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
I dont have a 99 i have a 02 but i love it!!
Old Jul 23, 2012 | 03:16 PM
FordGuy85's Avatar
FordGuy85
If the truck has atleast 4.10 or 4.30's you should be happy with it.
Side note, expect 10 mpg empty.
I have pulled 8k before with my 5.4l with no issues what so ever. Most iv pulled was 12k. You could deffinately feal the weight slowing the truck down but it did it no problem.
Surely the all mighty v10 will suit you well for sure.
Old Jul 23, 2012 | 03:31 PM
rc.chris's Avatar
rc.chris
Now looking at an 03 with 122000 miles.
Old Jul 23, 2012 | 03:39 PM
GoCamping's Avatar
GoCamping
A friend of mine just bought an 03 F350 v10 with 200k - threw some money into it to make sure all was good. Inspected by mechanic and did some ball joint work, replaced trans fluid / oil and some other various things. Spent about $500 after purchase I think. Then towed his "toolbox" work truck (OBS F250) a bunch of stuff and entire family out to SC from CA. Not a hiccup (trailer tires were a different story)...
Old Jul 24, 2012 | 04:51 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
We got a 2002 F250 4x4 V10 crew cab with 133,000 miles one of my favorite trucks. Does everything we use it for. I love it. It gets fair gas mileage we are getting 17.5 but our truck is slightly modified.
Trav
5 Star Tuning
Modular V10 (6.8l)
22
Feb 8, 2009 09:20 PM
Mike E.
Modular V10 (6.8l)
30
Jul 15, 2008 10:59 PM
uh60
Modular V10 (6.8l)
24
Dec 30, 2007 06:01 PM
CircleV
Modular V10 (6.8l)
Jan 31, 2004 05:10 PM
