Modular V10 (6.8l)
Question for TEAMMUDD!
Old Dec 28, 2007 | 09:17 PM
specializedcc's Avatar
specializedcc
Teammudd, it seems like you know a lot about exhaust issues. So heres my question. I have an 00 f-250 with the V-10, it is an off road truck mainly for hunting and mostly around the ranch, I emptied out the cat (to avoid starting fires in the feilds) and welded the empty core back in. There was a increase in power! 90k so it could have been plugged! However there is quite a drone at certain rpms. Im wondering if instead i should just run a peice of pipe in its place? Im thinking that would also be a smoother flow for the exhaust instead of it hammering around in that cat case? Thanks for any input!
Old Dec 29, 2007 | 04:17 PM
dkf's Avatar
dkf
It is not good just to gut the cat and put an empty cat housing back in, because it will cause turbulance in the exhaust. Put a piece of pipe straight through the inside of the cat and put it back on. Adding the pipe should help performance and drone. Anywhere in the US gutting or removing a cat is illegal, so keep it hush hush.
Old Dec 29, 2007 | 07:52 PM
specializedcc
just finished it today, now i need a new muffler. Its pretty loud now. Im thinking an fm 70 should quiet it down some, its the original muffler and 90k on it! Thanks for the input dfk !
Old Dec 30, 2007 | 12:54 PM
dkf's Avatar
dkf
The FM70 is about the quietest replacement muffler available besides another stock muffler. A dual offset 3" In/Out FM70 should fit the best. I have a pic of one in my gallery. The stock muffler will be the quietest muffler you can get however it is the most restrictive. The FM70 should give you a good sound. I like my FM70 however it is a little on the quiet side for my taste.
Old Dec 30, 2007 | 06:53 PM
specializedcc
I think that cat quiets the exhaust down quite a bit so i figured the 70 would be my safest bet for keeping it toned down without the cats help. The truck i had before was a straight piped 01 cummins, so the quietness is nice for hunting after two years of that noisy beast!
