LMC Rear Sliding Window
Old Nov 30, 2007 | 05:57 AM
1979FordF250's Avatar
1979FordF250
Has anyone purchased this item from LMC. I recently did and replaced my 28 yr old window and have leaks everywhere. The gasket doesnt fit right and is pulled away on all four corners!! I really dont wanna go caulking the crap out of it as it makes for a mess and shouldnt be necessary... Any input, ideas?
Old Nov 30, 2007 | 06:04 AM
scrapyardking's Avatar
scrapyardking
Why dont you check out some of the FTE sponsors before going to LMC, Ive bought stuff from LMC before and it was junk
Old Nov 30, 2007 | 09:17 AM
beartracks's Avatar
beartracks
I'm also not a fan of LMC but your problem may be with the gasket. I understand there is a later year gasket that doesn't quite fit right (vs 73/79)
Old Nov 30, 2007 | 09:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 = D3TZ-1042084-A .. Back Glass Weatherstrip
1980/96 = E7TZ-1542084-A .. Back Glass Weatherstrip
Old Nov 30, 2007 | 10:35 AM
1979FordF250
Ok I will doublecheck the PN, maybe they screwed up!THX
Old Nov 30, 2007 | 11:49 AM
Mil1ion's Avatar
Mil1ion
Maybe a moderator will copy this thread and put it in the comparing parts suppliers thread ?
It would be the logical ,common sense thing to do
Old Nov 30, 2007 | 12:44 PM
tylstruck's Avatar
tylstruck
I bought a sliding back glass from the local junkyard from an 80s Ford truck for my '79. From '73 to '96 is the same. I knocked out the glass using my hands with a bit of careful pressure, plus a screwdriver. For $40, I got it all plus the undamaged seal. All I did was buy a sliding window clip for $7 from Canadian Tire, and apply some oil for it to slide properly.
Selected the best one out there. Already tinted glass with very nice aluminum casing.
Tyl
Old Nov 30, 2007 | 03:14 PM
Drac's Avatar
Drac
Save the old ones
I bought my slider from the local glass company. The installer was reluctant to use the seal that I bought from Dennis Carpenter. But after he installed it, he said that was one of the best aftermarket seals he has ever seen.
Shawn
Old Nov 30, 2007 | 03:46 PM
Mil1ion's Avatar
Mil1ion
This thread is about inferior window gaskets from LMC.
Nothing more.
Old Nov 30, 2007 | 06:44 PM
ArcadeTom's Avatar
ArcadeTom
For what it is worth, I put in a C.R. Lawrence window (same one LMC and others all seem to sell) into my '74. I also used a new window gasket from a local parts company here. The gasket leaked like he!!. After talking with a local glass shop (which will install my windshield whn the painting is done) I found out that most of these older trucks need a black silicon sealant (only a little) along the groove that seals/locks the window in place. It is common and that came straight from the professional glass company.
Doubleclutch
15
Jul 21, 2015 11:21 AM
1950FordF1
Jul 18, 2015 01:24 PM
notthemaniusedtobe
26
Apr 2, 2015 02:07 PM
68fish
17
Dec 10, 2014 07:13 PM
ericford1984
Jan 21, 2012 04:07 PM
