ww
Old Nov 29, 2007 | 12:36 AM
kupaa's Avatar
kupaa
ww
I will be doing my ww next week and was wondering if i need to replace my o-ring for the turbo,i have 62000 miles and if so can i get them from napa?Thanks.
Old Nov 29, 2007 | 12:49 AM
Tenn01PSD350's Avatar
Tenn01PSD350
If it isn't leaking now, I wouldn't pull the turbo. I would do the PITA non-turbo R&R of the wheel only and be done. I have not done this, and do not plan to, but if this was what I was doing I would not pull the turbo. Others will say pull it. Not me. Asking for problems you don't need. Just lay across the engine and do it.
Old Nov 29, 2007 | 01:10 AM
kupaa's Avatar
kupaa
thanks for the advice cause i did not want to take of the turbo.
Old Nov 29, 2007 | 01:25 AM
Tenn01PSD350
Need a link for that job? I believe there is one right on FTE or you can check 7point3.com. Have fun.
Old Nov 29, 2007 | 01:45 AM
Izzy351's Avatar
Izzy351
I did mine without pulling the turbo. Stock up on ibuprofen or your favorite flavor of pain killers because you'll be sore afterwards. Here is a link to instructions:
http://www.blackclouddiesel.com/Tech/Superior%20Wheel%20Installation%20Guide.pdf
I didn't remove the wastegate actuator though. You can get enough clearance without. It's tight, but you can. Also, I didn't completely disconnect the spider. There was enough play in the boots that it cleared the housing. I used airtools for almost all of it and still was pretty sore. I also used two screwdrivers to bind the exhaust wheel -- only one seemed a little risky to me. Good luck.
Old Nov 29, 2007 | 01:49 AM
Tenn01PSD350
Where in the F are u at Joe? Stupid C5 still broke? I would have thought you were overhead by now.
Old Nov 29, 2007 | 02:02 AM
Izzy351's Avatar
Izzy351
lmao.... Just stopped at Charleston AFB to drop some cargo and refuel. Next stop: HOME!!
Have some time to kill, so I figured I'd jump on their WLAN.
Old Nov 29, 2007 | 03:19 AM
Izzy351's Avatar
Izzy351
Well, just got called to the plane. Next stop home...
Full Throttle
15
Apr 20, 2009 10:20 PM
silver&green94
Aerostar
13
Feb 8, 2009 03:01 PM
makomaker
35
Apr 29, 2008 07:57 AM
griff64
13
Mar 3, 2008 04:05 PM
guzzle92
Dec 6, 2005 07:29 PM
