flywheel problems with my ranger.
Old Dec 29, 2007 | 02:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Bdox
I think that Jared is onto the problem. I'm not entirely certain, but there is a part, between the crank and the flexplate, (flywheel,) like a pilot bushing that the front of the torque converter slips into. Maybe someone here knows ~ Bill perhaps? ~ if that part is different for the Ranger and the Explorer. If so, that would be a likely cause.
It is ahead of the flexplate and my just look like part of the crank if you don't know it's there.
I just looked at the Motorcraft site...it lists the same engine for both Ranger/Explorer. Unless = the vehicle was sold new in CA.
Some flexplates require a re-inforcement plate (Ford basic p/n 6A366).
It's usually 4-6" in diameter depending upon the application.
I STILL believe the two dowels (6A008) went missing when the engine was re-installed. No dowels = engine alignment problem...center of flexplate tears out.
Update
> > Explorer/Ranger/Aerostar starters are the same.
> > Explorer/Ranger use the same flexplate.
> > Aerostar uses a different flexplate.
Old Dec 29, 2007 | 04:36 AM
Pablo-UA's Avatar
Pablo-UA
One suggestion. Bent, damaged bellhousing.
Old Jan 2, 2008 | 02:27 AM
fordtruckgirl08's Avatar
fordtruckgirl08
Thumbs up thanks so much!
thanks guys!
my truck is gettin fixed as we speak!.. im gonna mention the damaged /bent bellhousing? and i told him about the dowel pins he's checking it out. as soon as i get it fixed im gonna upgrade to a 2oo5 ford escape, because im goin off to college & need something reliable..its still a ford [=... thanks again.. for all your helP! >!EriN!<
Old Jan 2, 2008 | 01:11 PM
RangerPilot's Avatar
RangerPilot
Good plan. If your college is anything like mine, you'll be happy to have something short wheelbase you can cram in all kinds of small parking spots and parallel spaces.
Old Jan 2, 2008 | 11:26 PM
FORD RANGER's Avatar
FORD RANGER
hey girl,
too much end play in the crank shaft in the engine.that is what cracks flex plates!
it will move foreward and backwards. depending on the miles on said ranger! and how much the motor is worn as well. they pull against each other. under acceleration the crank will move forward, and at the same time the torque converter is pulling the opposite direction. due to front pump suction. hense broken flex plates. and ruined starters.
ford ranger
Old Jan 3, 2008 | 06:52 AM
Pablo-UA's Avatar
Pablo-UA
His truck is not so old. This trouble is tipical for 600-800K engines. My old 3.0 with 700 k on clock has 0.7mm play. It is not normal but not enought to damage flightwheel.
Old Jan 3, 2008 | 06:38 PM
fordtruckgirl08
that will work with me if you can figure out if the starters are the same.. ive heard different .. it is the same it isnt the same.. so i was just gonna see!.. thanks for your help! and the dowel pins are still there.
Old Jan 3, 2008 | 09:48 PM
FORD RANGER
so thats not the problem! my next question would be are you bell bolts tight? of course
that would make the front pump seal leak.
ford ranger
Old Jan 4, 2008 | 01:16 AM
Pablo-UA's Avatar
Pablo-UA
Well, from the beggining. I tried to read all the suggestions from the beggining and I cann not understand what destroys all. I wanna see pics. I may help us to understand what a hell is going on....
Old Jan 4, 2008 | 10:13 AM
Bdox's Avatar
Bdox
Go back to this plate that Bill mentioned:
If that is absent, or on the wrong side of the flexplate, when the bolts are tightened then the flexplate is stressed right where you breaking has occurred.
Old Jan 4, 2008 | 07:58 PM
FORD RANGER
isn't there a spacer between the crankshaft and flexplate?
ford ranger
Old Jan 4, 2008 | 11:09 PM
Bdox's Avatar
Bdox
ford ranger
Yes, it also acts as a pilot bushing for the front of the converter.
That part, spacer, whatchacallit is what I was asking about earlier, is it the same part for Ranger and for Explorer?
But the main point is, when the assembly is bolted together, is the flexplate stressed in any way?
Old Jan 5, 2008 | 01:06 PM
  #28
FORD RANGER
it should be the same part. every time i put a transmission in one of those trucks i change the spacer/pilot.
ford ranger
Old Feb 19, 2010 | 06:56 AM
  #29
jtmilazzo's Avatar
jtmilazzo
Kevin:
Sounds like you described my problem. 1986 Ranger, 2.9L with Auto. Starter has been making terrible noise for a couple of weeks. Thought it was the starter drive, so replaced it, but no change. While starter was off, I checked all the ring gear teeth, and they looked OK (for a truck with 190K on it). But I figure the noise was the flex plate wobbling cause last night, stopped pulling, like a bad trans, but starter spins but does not rotate engine. 2-3 hours huh? I think your record is safe! Thanks for the info, looks like a fun weekend ahead for me.
jtmilazzo
TyBragg
124
Jul 22, 2023 01:07 PM
Corn
Jan 1, 2020 03:48 AM
Ravenjinn82
Sep 11, 2015 02:08 PM
rmckenna
Sep 14, 2006 04:30 PM
Twissted
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 2, 2006 08:15 PM
