I'm just finishing installing my new Cali fuel pump and i have a wired plug that does not appear to go any where.
It come up between the HPOP and the fuel filter. It is a two (2) wired mini plug with a plastic male snout with two (2) female ports. I also has a wire bale attached to it's side to hold it in place.
Rick:
If it goes there I sure as hell can't find it. What I do know is the the truck will not start so it's very possible that it's a critical plug. I'm sure that you are probablr right as it doesn't have enough lengh to go any where else.
Rick:
I'll just keep looking.
Rog
Rog
Increase the screen resolution on the pic I sent . you see th IPR is labled,, there is a tin nut , a spacer ,then a solonoid. On top of the solonoid , is a two wire plug.. that is where the wire goes...
Everyone of you were right. It is way down in the valley of death. I just had to get my trained monkey with two elbows and two wrists on both arms and we got it plugged in.
