Gearing! Little help please?
Old Nov 28, 2007 | 10:25 AM
6CylBill's Avatar
6CylBill
Hey guys. I looked for the proper place to put this. I even did a search. I hope this is correct.
I'm wanting to replace my 3.08's with 4.11 gears. I looked at Jegs but they are pretty pricey. What is the best way to find and buy gears? What are the going prices??? Would it be a good idea to go look at a junkyard?
Thank you in advance!
Ps. How do I find out what kind of rear I have? 7.5, 8.8?(if those are even the correct types) I know I don't have a 9 inch. I'm pretty confused! =( I looked for numbers but couldn't find anything other than the metal tag that tells me what I'm geared.
Old Nov 29, 2007 | 10:24 PM
Pkupman82's Avatar
Pkupman82
You have the 8.8" rear end Bill. Are you sure you want to run 4.11s (actually 4.10s)? That is pretty low, it will hurt you on top end even with the overdrive trans. Unless you plan on lifting your truck and putting 33s on it or something... that will be too much gear. I would suggest more like a 3.73, this gear is very common in the 4.0 powered Rangers and Explorers (which also used 8.8s) Some of them came with Trac Lok limited slips... if you're lucky you could score a limited slip too. These parts can be had at any boneyard for a much better price than new, then I would suggest getting a bearing/ gear install kit. Going the used route might be a bit more economical, just make sure to inspect the gears for damage and excessive wear before you lay down any cash.
Old Nov 30, 2007 | 06:54 AM
teds74ford's Avatar
teds74ford
I also would suggest staying away from the 4.11s unless you are installing bigger tires. The 300 just doesn't love revving, and 4.11s would definitely put the rpms up.
For what it's worth, I had 4.10s with 33s and didn't like it, so I switched to 36s to drop the rpms. I am much happier now.
Old Nov 30, 2007 | 07:21 AM
TallPaul's Avatar
TallPaul
My F150 has 3.08 and it is pretty good. I get chirps off the tires if I mash it at a slow roll in first. I get wheel hop if dirty road or damp road. When I needed to replace the rear end (pinion went) I got another 3.08 from boneyard for $250 that only had 40K miles on it, came with brakes and all. I considered a 3.53, but everything other than 3.08 seemed pricy and I didn't want to lose the nice 70 mph 2050 rpm cruise speed.
I think a 3.53 or 3.73 would be plenty for you. F150s came with 3.53s too. But for me, I came off an '84 that had a 2.73 rear and a highway tranny (4 spd including od). Total combo on the '84 had first gear nearly like second gear in my '95, so I had/have no desire to go lower gearing on my '95. But yeah, boneyard unit is probably a lot easier/cheaper way to go.
Old Nov 30, 2007 | 08:38 AM
optikal illushun's Avatar
optikal illushun
what size tires are u gunna run? do u tow? do u want more get up n go?
id say 3:55s if ur gunna run 235/75/15s and 3:73s if ur gunna run 31s. should put u in a good power band.
Old Nov 30, 2007 | 01:08 PM
6CylBill's Avatar
6CylBill
I plan on putting 31x10x50's on, which is why I wanted to go to the lower gear so I wouldn't lose any torque. I don't mind cruising at 60mph. I don't pull any heavy loads but I do pull stumps and I love truck pulls. I'll be needing new tires soon and I wanted to go to 31's but I didn't want to lose any power.
Thanks to all of you for your imput! I really appriciate it. I always get my questions answered here.
Old Nov 30, 2007 | 01:30 PM
Pkupman82's Avatar
Pkupman82
For 31s I would say 3.73s would be perfect, you will have plenty of grunt for pulling.
Old Nov 30, 2007 | 02:14 PM
StangLX302's Avatar
StangLX302
I have 32" tires and a 3.73 seems about perfect for it. I bought the gear set on eBay for just $20.00 and a Traction Lok unit for $25.00. The parts were factory stock for an Explorer. Changing the gear was about the best "bang for the buck" thing I've done. Also, while you in there, if you have a 'one wheel wonder' consider putting a Traction Lok in there as well. I don't get stuck in the snow/mud anymore, like I used to.
If you go junk yard hunting, the tag will say 3L73, meaning 3:73 with a locker. 3O73 means it is an open diff.
Old Nov 30, 2007 | 02:20 PM
andym's Avatar
andym
If it's a 4x4, remember that you have to change the front as well.
Finding a used rear axle in the junkyard will be difficult. Most of the F-150's and Bronco's had either 3.08 or 3.55. An explorer axle won't work because the bolt pattern is different and the perches won't line up.
New gears are going to run $200 or so a set, and most people decide to pay to have it done because it's a lot of work and beyond the capabilities of most backyard mechanics.
Old Nov 30, 2007 | 02:51 PM
Silver Streak's Avatar
Silver Streak
I bought my Trac-Loc on ebay for $100. Beware getting one for an Explorer, they aren't all 31 spline like the trucks are.
New gears are worth the money.
Old Nov 30, 2007 | 04:29 PM
Pkupman82's Avatar
Pkupman82
I installed a Traction Loc (nice piece) in the front of my 84 F150 4x4 when I did the swap from 3.08s to 4.10s along with a Powertrax locker in the rear and 33" mudders... that truck is unstoppable! 33s and 4.10s are a bit low for the freeway but you will have all the power you need in the woods. With the mods I am running on the motor I think I can afford stepping up to 35s... which is in the plans of my frame off rebuild this truck is currently undergoing.
Old Nov 30, 2007 | 06:26 PM
6CylBill's Avatar
6CylBill
Unstoppable is what I'm going for ^. I want to make this truck a beast. I want to be able to hook up to any V8 powered pickup and pull it sideways through mud and Hell itself!
Old Nov 30, 2007 | 06:44 PM
hoxiii's Avatar
hoxiii
Think about this-
If you go to 4.11's your cruise rpm would still be lower than if you downshifted your current setup into 3rd.
If you went 4.40's (they don't exist for an 8.8) you'd have the same cruise RPM as if you downshifted your current setup into 3rd.
Now, if you went 4.56's and 31x10.50's you'd have nearly the same cruise RPM as 3.08's in 3rd with your setup.
Justin
Old May 16, 2012 | 04:32 PM
Stan Balafas's Avatar
Stan Balafas
4WD Gear Calculator Web Page
See Gear Ratio Calculator
this has all you need for driveline numbers and RPM and tire sizes and ... well everything for 4WD gearing calc.
Regards
Stan
wharthog
Dec 31, 2016 06:22 PM
jtart2
1978 - 1996 Big Bronco
Mar 8, 2016 06:39 AM
nolan62
Jun 27, 2013 03:20 PM
iwannanSC
22
Jul 15, 2009 11:46 PM
Pioneer Ford
May 30, 2002 08:58 AM
