Need tranny info for rearend swap
Ok, I have looked everywhere. I even emailed Tremec support with no luck. I'll be swapping out my 86 F150's rearend soon for a nice new unit. But I'm going from a 2.47 gear to a 3.31. I know I'll need a new Driven gear for the Speedometer cable to correct my gauge. I need one more bit of information and I can't seem to find it anywhere. I hope someone here knows. I need to know the tooth count of the Drive gear in my transmission. It is the 3spd + 4th OD - The transmission shop called it a Tremec RTS. Anyone know?
Ed
Ed
SROD or variant. Just pull your existing driven gear. Since you are going to a 3.31 from a 2.47, you will need a larger driven gear.
You are going from 44 mph per 1000 rpm to 33 mph per 1000 rpm.
I would try 3 teeth larger than what you have, if you can get it.
If you have to change the drive gear, it would be a real question as to if that would be worth the effort.
All the driven gears are the same for years and years and years, so it should not be hard to find.
Teeth on DRIVEN (end of cable) & DRIVE (output shaft) speedometer gears based on rear axle ratio, trans type and tire size.
RUG SR-OD (Single Rail 4 Speed Overdrive) = 1978/83 E/F100/150 300/302 & 1978/79 E100/150 351W / Misc 1978/83 Passenger Cars.
RTS TS-OD (Top Shift 4 Speed Overdrive) = 1984/89 E/F150 300/302.
C3/C4/C5/C6/AOD: The is no part number for a DRIVE gear since it's made as part of the output shaft.
See examples:
See examples:
crestfallinman
06-26-2016 04:08 PM
PetesPonies
06-02-2010 11:04 PM
cdherman
10-07-2003 07:25 PM
Mky67156
08-12-2003 09:41 AM
