6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Squeaky belt when cold
Old Nov 27, 2007 | 05:16 PM
08350's Avatar
08350
It has started to get cold here in Boston and I've noticed that when I start my truck, the belt will squeal very loud. I took it in for service today and there was a bulletin about this. They are replacing the belt and pulley tomorrow. There was also a bulletin regarding the lights on trucks with the snowplow package, so they had to do a reflash of some sort to the light control module. I'm not sure on the details, but I will update when I pick it up tomorrow.
Old Nov 28, 2007 | 02:34 PM
txharley's Avatar
txharley
My 6.0 did the same thing. New idler pulley, waterpump pulley, and belt solved the problem.
Old Nov 28, 2007 | 05:48 PM
fordfish's Avatar
fordfish
condensation (water) will do the same thing sometimes too.
Old Nov 28, 2007 | 08:11 PM
DeereTech05's Avatar
DeereTech05
Do you know what the number on the bulletin is?? I had mine to the dealer several months ago and they said they were investigating the problem and they would get back with me, but they never have.......
Old Dec 6, 2007 | 01:22 PM
josh250's Avatar
josh250
In the Shop Now for Cold Start Squeak
I just got off the phone regading my truck being in the shop for this same problem. I don't have a bulletin number, but the service folks said they have an updated bulletin that says the Idler Pully is what has been identified as causing the problem. I had it there before for the same problem and they replaced the Outer Tensioner Pulley but that didn't help anything in case they try the same thing for ya'll.
Josh
Old Dec 6, 2007 | 04:41 PM
bnmccoy's Avatar
bnmccoy
Cold weather belt chirp - 6.4 diesel
The TSB is 07-23-9 dated November 9, 2007
7C3Z-8678-B is idler pulley kit part number
Old Dec 6, 2007 | 06:45 PM
bnmccoy's Avatar
bnmccoy
This is a link to the snowplow TSB on lighting at the fleet website.
http://www.fleet.ford.com/truckbbas/non-html/Q155R1.pdf
The Ford TSB is 07-9-1 dated April 19, 2007
it is for vehicles built before 4/18/07
4inchlovin
16
Apr 19, 2013 08:06 AM
Steadyman321
Feb 2, 2012 12:32 AM
#1PATSFAN
Sep 12, 2008 08:35 PM
SonicBlueF350
Jan 29, 2005 09:45 AM
Bodytech5
Jan 27, 2005 06:55 PM
