Does this sound like the CPS
Old Nov 27, 2007 | 10:58 AM
Flea's Avatar
Flea
Driving down the road and the truck powers off completely, no nothing, coast over to the side of the road and truck will turn over but no movement on the tach. WTS light won't come on. But truck will crank.
thanks,
Fletch
Old Nov 27, 2007 | 11:08 AM
tndiesel's Avatar
tndiesel
There are definitely people on here with more knowledge than me but I would sure try replacing the CPS first. It's cheap.
Old Nov 27, 2007 | 11:58 AM
Flea's Avatar
Flea
Does this sound like the fuel heater?
Old Nov 27, 2007 | 12:15 PM
Action4478's Avatar
Action4478
Yes,, unplug it & replace fuse # 22
Heater wire ...here....
Old Nov 27, 2007 | 12:31 PM
westtntrucker's Avatar
westtntrucker
If there is no movement of the tach when cranking as you stated, then it is the CPS.
Old Nov 27, 2007 | 12:39 PM
Action4478's Avatar
Action4478
This is why I suggested the fuel heater......
Old Nov 27, 2007 | 01:27 PM
Neal 97 250's Avatar
Neal 97 250
Heck do both a fuse and a CPS are cheap. But do one at a time to see which fixes it. My vote CPS.
Old Nov 27, 2007 | 01:39 PM
Action4478's Avatar
Action4478
I'm with you on the cheap, but unless his WTS light is burned out , this would be a first....
Old Nov 27, 2007 | 02:49 PM
tjbeggs's Avatar
tjbeggs
Yep no WTS light....if it normally lights his PCM has no voltage. Fuel heater/pcm fuse first then CPS
Old Nov 27, 2007 | 02:58 PM
scatgo's Avatar
scatgo
Sorry but I am new to all this. What is a cps wts?
Old Nov 27, 2007 | 03:30 PM
westtntrucker
CPS= crankshaft position sensor, WTS= wait to start light on dash
Old Nov 27, 2007 | 04:46 PM
Action4478's Avatar
Action4478
Some reading for you..... here......Many more if you need them
Old Nov 27, 2007 | 04:58 PM
scatgo's Avatar
scatgo
Thanks. That will help a lot.
Latter.....
Old Nov 27, 2007 | 06:07 PM
Flea's Avatar
Flea
It was the fuse. I pulled the bottom red wire and rubber gromet off the driver's side of the fuel bowl and replaced fuse and truck started right up.
Now, how to get the fuel heater back to working. I pulled out the fuel filter and the loop wires that you can see, that the filter sits on has lost it solder on one side.
The Ford Truck dealer here quoted me $56 for the fuel heater with the part # of
F5TZ9J294A. Is this what I need?
They told me their is an internal heater and an external heater.
How hard is this job and what tools will I need?
Thanks,
Fletch
Old Nov 27, 2007 | 06:17 PM
F350_Hauler's Avatar
F350_Hauler
Smile Don't ya just love easy fixes that get you right back in the saddle?
Just leave it unplugged. You really don't need it unless it gets very cold, like around zero. Easy for me to say, I live in South Florida.
