drivetrain identification
Old Jan 11, 2008 | 07:30 AM
alxsnmr's Avatar
alxsnmr
ATF has been used in the ZF's for awhile, some of the newer ZF's include transmission cooling lines similar to the automatic transmission cooler. It flows better to all the bearings than the heavier fluid, and somewhere here someone mentioned that the ZF has all ball bearings and none of the bushing/bearings. On the down side you have to change the fluid a little more often than you would in the old NP435 and T-18's. Come to think of it most of the agricultural tractors run hydralic fluid in the transmissions as a lubricant as well as operation of hydralics on equipment, it is only different from ATF by not having friction modifier in it.
Old Feb 10, 2008 | 07:43 PM
mememe's Avatar
mememe
saw on his tag has 235/85/16 tires thats 32inch if it come with 3.55 gears seams like that would be a bit off and underpowered for coming from the factory that way or am i mistaken?
Iconic
Feb 21, 2017 12:16 AM
travis.k.hirt
Jan 12, 2015 04:55 PM
Swoop03
Sep 19, 2013 01:09 AM
51chris
1978 - 1996 Big Bronco
Apr 1, 2013 07:53 PM
mwc4275
1966 - 1977 Early Broncos
Mar 18, 2003 10:33 PM
