I tried to find that also on the ford parts stores online but they didn't even list a heated mirror just standard and signal
you might check your local dealer
Signal too?
Thank you, Ray, I'll give them a call.
The Ford stealership in Corpus, $48.60 including tax title license, the whole bowl of chili and I didn't have to wait or pay freight...
So, I'm happy and back in business.
Thanks all for the help'
Good luck Kwik, you'll find them I'm sure.
For standard mirror glass PEP boys and most auto stores either carry it or can order it. As for heated ones I found them on the web, heated glass only, but have not tried contacting the suppliers for a price, Safelite is one of the main outlets from the manufacturer. If I do decide to try I will keep all posted.
That would be great. What I am interested to know is if a heated glass will mount in an unheated enclosure. If that is the case I can run a couple of wires and mount a switch
Sorry, I have been out for a while. At 40.00 though, that is probably the same. I haven't had any problems from fastparts, but you never know. Glad to hear that you got it fixed.
As far as the heated, I'd like heated as well, wonder if the dealer could show you a side by side of the glass, should be pretty evident if they are the same mount.
The only problem I see with the dealer, at least the one I went to is they use the serial # to make sure they get the right one. I guess if a friend has a heated one, compare size etc then use his serial #. Unless you've got a friend at the dealer.
Good luck.
Can anyone tell me why for wants 40 bux for the heated mirror on the drives side and 100 bux for the passanger side ? ?. . . . And of corse my broken mirror is on the expensive side
Go to Directfordparts.com, one of our sponsors, if you can't find it on there website, drop them an email and one of them will respond soon. I have had good success and they have very good prices.
I'm guessing someone quoted you the non heated mirror for $40. If you can get the heated glass on the drivers side for $40 be sure and let kwikkordead know. He's been looking at heated mirrors.
