mirror on pass. side
Old Nov 25, 2007 | 08:48 PM
RobertJohn's Avatar
RobertJohn
On my early '99 I have the big towing morrors that are adjustable from inside. While deer hunting my son hit a small tree with the pass. side mirror and it folded in but the large mirror popped out and broke.
Can I just get a replacement mirror or do I have to replace the entire unit ? If I can get a mirror where is a good place, any sponsors ?
Thanks..
Old Nov 25, 2007 | 08:54 PM
cangim's Avatar
cangim
Your can get just the glass, I ordered the small piece a while back from fastpartsnetwork.
Old Nov 26, 2007 | 07:44 AM
Kwikkordead's Avatar
Kwikkordead
Do the heated ones fit the unheated sockets?
My late '99 mirrors are not heated and it's hard to see in bad weather when the mirror is all fogged up.
It would be a simple matter of running a couple of wires to a switch
Old Nov 26, 2007 | 02:42 PM
RobertJohn's Avatar
RobertJohn
cangim or whomever knows......laffin
are there connectors on the back side of the mirror ?
it looks like there should be two or three clips to fit the
base ?
Old Nov 26, 2007 | 03:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I went to my local glass store and they installed a new mirror. I don't remember the cost, but I thought it was a good price.
Old Nov 26, 2007 | 03:10 PM
RobertJohn's Avatar
RobertJohn
and another question...
does fastpartsnetwork. have a phone # ?
all I can findis e mail
Old Nov 26, 2007 | 04:04 PM
RobertJohn's Avatar
RobertJohn
Well I'm glad cangim that you got your order... I've exchanged 27 e mails with fastpartsnetwork in the past hour and finally cried uncle and told them to cancel anything I'd ordered...this was one of those cluster "things" and I've had enough.. I'll just go to my stealership and pay what they want...... I never in my 62 years thought ordering a mirror would be such fun...I need a valium and several scotch and sodas now......whew
Old Nov 26, 2007 | 08:24 PM
F350-6's Avatar
F350-6
I just replaced the passenger mirror on mine about 2 weeks ago. I needed the glass ASAP so I went to the local Ford house. It was around $40 for the big upper glass piece. It came with the plastic pins and instructions. Note: Read the instructions. It will save you 30 min. of disassembling / reassembling parts that don't need to be removed. The bottom glass on mine was not broken so I did not get that part.
If you're not in a big hurry you might save a few bucks. http://catalog.powerstrokeshop.com/p...layCatalogid=0
Old Nov 26, 2007 | 09:11 PM
RobertJohn's Avatar
RobertJohn
Thanks, after my ordeal with fastparts, I'm going to the stealership tomorrow. And thanks for the tips on the instructions as well.
Old Nov 26, 2007 | 09:21 PM
rbaker6336's Avatar
rbaker6336
mine was a little over $40 at dealer
Old Nov 26, 2007 | 10:51 PM
Kwikkordead
$40.00 is very reasonable for a heated mirror.
Old Nov 27, 2007 | 06:04 AM
F350-6's Avatar
F350-6
$40 is for the non-heated variety. I had a trailer to hook up to so I didn't have time to look into wiring a heated set. I'm sure the heated ones will be more.
Old Nov 27, 2007 | 06:18 AM
SprintRacer26's Avatar
SprintRacer26
I've got a good used complete pass. side mirror i'll sale for $50, it is off a '99 and doesn't extend/collapse.
Old Nov 27, 2007 | 07:58 AM
Kwikkordead
Figures.
Do you know if the mounting system is the same for heated vs unheated mirrors besides the two electrical connections?
I have two perfectly good non-adjustable, non-heated mirror assemblies that are good enough to see around the trailer when I am towing, but in wet weather they are useless without heat. It would be fairly simple to mount some heated mirrors and run a couple of wires through the arms.
Old Nov 27, 2007 | 08:08 AM
rbaker6336's Avatar
rbaker6336
I tried to find that also on the ford parts stores online but they didn't even list a heated mirror just standard and signal
you might check your local dealer
