7.3 to 550 cubes
Old Nov 24, 2007 | 06:11 PM
2 stroke man's Avatar
2 stroke man
7.3 to 550 cubes
i heard today that you can go to a junk yard and get crank and rods out of a big 550 international v8 motor and bore out our trucks and add that crank and pistons and rods, and crank the fuel up, and abra kadabra, you got an even bigger beast than we got!
Old Nov 24, 2007 | 06:37 PM
FFemt5287's Avatar
FFemt5287
if this is true, we have sparked my interest........
Old Nov 24, 2007 | 06:58 PM
79f-250custom's Avatar
79f-250custom
can you even bore PS's out that much to fit a 550 piston in it????
Mitch
Old Nov 24, 2007 | 07:28 PM
barebackjake's Avatar
barebackjake
hmm first ive heard, id imagine the v-549 has a longer stroke which i bet makes alot of the extra displacement there. the 549 is a MUCH bigger motor than ours ive seen alot of theese on generator sets i cant imagine the crank would fit in our blocks
Old Nov 24, 2007 | 07:50 PM
2 stroke man
ya the guy said it would fit. just change crank, bore it, pistons, and buy a fuel refinery
Old Nov 25, 2007 | 08:54 AM
c00nhunterjoe's Avatar
c00nhunterjoe
very interesting i am still skeptical though, imagine the injector uprada needed just to run it
Old Nov 25, 2007 | 09:30 AM
Knotwild's Avatar
Knotwild
550 V8
In 1989 I was in the fertilizer business and I ran two IH diesel 4x4 spreader trucks. One ran the DT 466 and the other had the 550 in it. It was a massive motor, naturally aspirated, and to this day, I have never seen anything make the low end torque that motor did. It would walk off with 10 tons of lime in a bottom plowed field. With the turbo DT466 I had to pack some ruts in low range first gear, then back up and get a running start. If I didn't keep the rpms up, it would stall in a turn. The 550 just kept going and would pull the rpms right back up after a turn. I can't imagine all of that in a pickup or what it would do if you hung a turbo on it!
Old Nov 25, 2007 | 04:38 PM
tfrugal's Avatar
tfrugal
i thought the 6.9 was based on the 406/ 446 engine.... i will do some looking in the books, but i doubt they interchange...
Old Nov 25, 2007 | 05:32 PM
tfrugal's Avatar
tfrugal
my books dont have anything like crank length... the crank journals are are 3.2495-3.2506 (406) and 3.124-3.125 (549) so i dont think so...
the 446 is 3.1228-3.1236, the 537 and 605 is 3.1235-3.1245, 478 is the same as 549.
hope this helps, i dont have a manual that covers the 6.9/7.3
