broken fuel pressure regulator
Old Nov 25, 2007 | 06:56 PM
tbirdage's Avatar
tbirdage
A non-mechanic buddy of mine has a '96 psd and was plugging the fuel filter clogged sensor hole to fix a leaky one. He overtorqued it and busted the housing. Can anybody tell me where I can get the complete fpr? Also, are there any adjustments I need to make to the new one? Thanks in advance
Old Nov 25, 2007 | 07:04 PM
Neal 97 250's Avatar
Neal 97 250
New or used?
ebay for new. You may even find a used one there. or try a junkyard for a used one but get one off a '96 or '97.
I guess he should have just gotten a new sending unit to fix the leak, Huh?
Old Nov 25, 2007 | 07:09 PM
tbirdage's Avatar
tbirdage
New one would be fine. He needs whatever is the quickest and I see all these links out there on the web, thought sombody out there may have already done the research. Ebay just laughs at me when I do a search, so I'm going to make the assumption that it is not a commonly replaced part
Old Nov 25, 2007 | 07:15 PM
Neal 97 250
Quickest is the "Stealership". Though they may be expensive. You could check the local parts houses they are still open tonight. Cheapest may be e-bay though. I will see what I can find for you.
Old Nov 25, 2007 | 07:17 PM
tbirdage's Avatar
tbirdage
10-4, thanks
Old Nov 25, 2007 | 07:24 PM
Neal 97 250
Look here. http://catalog.powerstrokeshop.com/p...&subcat1=86780
I couldn't find one on ebay yet but they will be there. I found one for a 99 but it was 275.00.
You may be able to just order the filter header # 9B249 on the link above, see here: http://catalog.powerstrokeshop.com/p...&subcat2=86785
doc7f
1997 - 2003 F150
Oct 23, 2023 06:54 PM
robjs111
Jul 7, 2008 11:20 AM
cdiddy
Aug 27, 2007 12:18 AM
mauicruza
1966 - 1977 Early Broncos
13
Feb 10, 2005 05:37 AM
