not a t18 np???
Old Nov 24, 2007 | 04:41 PM
mousetrap65's Avatar
mousetrap65
Question not a t18 np???
I have a granny low 4 speed trans behind a 85 300, it is a np??? top loader
everyone said it was a t18 but isnt that a borg warner mine has a big np
with a gear around it on the side of the case what are the numbers I need
to get a seal kit for it it has a pto cover on the pass side or right side if you sat ot tailshaft looking at bellhousing
thanks for the help
Old Nov 24, 2007 | 05:44 PM
flipklos's Avatar
flipklos
Over and up for reverse is a BW T-18/T-98 Tranny
Over and Down is an NP
Old Nov 24, 2007 | 05:46 PM
flipklos's Avatar
flipklos
I belive the Serrial is on the "bump" on the bottom.
Old Nov 24, 2007 | 06:51 PM
mousetrap65
i go over down np what
Old Nov 24, 2007 | 08:56 PM
1980FORD's Avatar
1980FORD
I have a T-18 tranny in my F-150 and it is over and down for reverse. If it is a NP it may be a np435. I don't know what other tranny's they used. If you run the sticker on your door, and it is the stock tranny it will tell you.
Old Nov 25, 2007 | 12:07 AM
optikal illushun's Avatar
optikal illushun
dont the nps have an alminium shift top?
Old Nov 25, 2007 | 05:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
New Process 435: The cap (B8T-7220-D) to hold the shift lever into the tower is secured by 2 pins, and twists off.
Warner Transmissions: The cap (8MTH-7220) to hold the shift lever into the shift tower screws off/on.
Old Nov 25, 2007 | 10:39 AM
mousetrap65
thanks #s for a crabby old grouch you know your stuff, that cap # said it all
i have a np 435 now I can get the right seal gasket set
Old Nov 25, 2007 | 10:40 AM
mousetrap65
yes it has an alluminum top
Old Nov 25, 2007 | 05:51 PM
NumberDummy
D5TZ-7153-A .. NP435 Transmission Gasket Set ~ Fits: 1957 thru the 1990's.
The seals don't come with the gasket set.
1957/91 F100/350: Front Seal: C4TZ-7048-A (New Process p/n: 95827)
1980/91 F150/350: Extension housing seal: D9BZ-7052-A.
Old Nov 25, 2007 | 05:54 PM
optikal illushun
hehe, crabby ol grouch. but dam, he can be as ornary as he wants...he knows his stuff
petrovich79f250
Dec 19, 2020 09:37 AM
TA455HO
Mar 18, 2013 10:10 AM
RossOlson
16
Jun 24, 2010 02:52 PM
Torque Lover
Jan 19, 2005 06:57 PM
onebad40willys
Jan 23, 2002 08:57 PM
