Is it bad to drive at low RPMs???
everyone knows the 300's have awsome bottom end power. infact i take all of my 90 degree turns in 3rd gear, and it just chugs alone with out a problem. i know most engines can not drop down to 900 RPM or so during regular driving. so my question is is this harmful to my engine? i get some vibration when the RPMs drop that low (not alot) but the engine dosent seem at all fased by this. the only thing i can think of is it may not get enough lubercation at these low RPMs, or the slight vibration could loosen something up?. any one have a more informed opinion??
You are right about low oil pressure at low revs being an issue, especially if you are into the throttle a bit, lugging it and bringing cylinder pressures and therefore bearing pressures up.
Also, the gear box would rather spin a little faster under load as well.
Shift it down....
You can always skip gears on the way up and use the low end to accelerate at an even slower rate than usual if you like to show off the low end grunt...
900 in 3rd is a kiss away from a stall, imo.
Shift it down....
Low RPM lugging is the worst thing you can do to your engine. The torque required to accelerate at low rpm's is much greater than if you went down a gear. This is hard on the bearings, as evidenced by the vibrations you are getting. Your engine will run much longer if you keep the rpm's up enough to prevent lugging.
Over revving IS the WORST thing you can do to a motor!! As long as the oil pressure
is good and you are not towing or heavily loaded that will be fine to bring the motor down to now if you said 600 rpm that is a different story!!http://www3.telus.net/cbradley/Engin...fications.html
is good and you are not towing or heavily loaded that will be fine to bring the motor down to now if you said 600 rpm that is a different story!!http://www3.telus.net/cbradley/Engine_Specifications.html
As long as it's not bucking, shuddering, etc., at low speed under light to moderate throttle it isn't getting hurt. I routinely make a 90 degree right turn in third gear (3.08 rear and stock tires) at 10 mph with rpm dropping below 1000 with no problem. In town traffic I routinely upshift at 1500 rpm...again no problem. Driving on a 30 mph street in fourth at 1000 rpm...no problem. If traffic conditions dictate accelerating quickly using more than light to moderate throttle or one has a moderate to heavy load on or in tow by all means run it a little faster. Otherwise, don't worry about it.
IreallyLikeFords
34
04-27-2009 09:59 PM
speedworks
01-05-2008 08:45 PM
