brake problem. abs?
Old Nov 24, 2007 | 02:10 PM
misfit36's Avatar
misfit36
brake problem. abs?
hello everyone. ive got a 2001 explorer sport with 60,000 mi. just recently maybe 3 months ago i had new rear calipers put on and rotors cut. in the past couple weeks i noticed something quite scary actually. in dry weather and only occaisonally when i apply the brakes and am about to come to a stop. the brake pedal "chatters" for a second or two like the abs is on and it takes a second for the truck to come to a complete stop. the abs light does not come on when this happens. im wondering if anyone has had a problem like this or knows the problem. it doesnt happen everytime but ive almost ran over my Sportster when parking behind it. scared the hell outta me. thanks
Old Nov 24, 2007 | 10:08 PM
99f350sd's Avatar
99f350sd
You have a rust issue or missing tooth or bad sensor somewhere on a wheel. I had a taurus we had to pull the abs fuse. Fine now.
Dick
Old Nov 25, 2007 | 06:34 PM
steelers06steelers's Avatar
steelers06steelers
My 2001 SportTrac does the same thing, only with light brake applications. Let me know what you find on yours...
Old Nov 27, 2007 | 04:51 PM
misfit36's Avatar
misfit36
when you say you pulled the abvs fuse and are fine now, do you mean ive just blown a fuse? im confused. sorry, im not a technician so im not to sure about more technical stuff. thanks
Old Nov 27, 2007 | 09:08 PM
99f350sd's Avatar
99f350sd
The abs works like this: Each wheel has a toothed ring and sensor each of 4 sensors goes to the abs computer. If say each wheel is spinning at say 20rpm and the left front goes to 5 rpm the computer is figureing that its locking so its gonna free it up. The reason why it see's a locked up situation without actually haveing one is the teeth on the ring are rusted or a sensor is bad falsley indicating a locked wheel. In my situation we just took out the abs fuse so it won't release the brakes..
Dick
Old Nov 28, 2007 | 10:39 AM
misfit36's Avatar
misfit36
oh i see now. thanks for clearing up. im assuming its best to replace the sensor than to just remove the fuse. anyone have pics of what this sensor looks like? and how much a new one would go for? id appreciate it. for the time being would you suggest i remove the fuse? thanks again
Old Nov 28, 2007 | 04:36 PM
99f350sd's Avatar
99f350sd
You have to get the system checked by a prof mech...Dealer most likely.
Old Nov 28, 2007 | 05:01 PM
steve(ill)'s Avatar
steve(ill)
if you disconnect one sensor, the light comes on, and the system stops working. pull the plug on one of the front sensors and see if the problems stops, or is something else.
Old Nov 28, 2007 | 05:04 PM
eaglestone's Avatar
eaglestone
Before spending $130 for a front sensor (or anything else), I just fixed this very problem yesterday. I replaced the rear and front sensors with no luck. I bought new pads and, while installing them, cleaned rust off everything around the calipers, disk shield, and reseated the sensors (after cleaning the metal they're seated on). I also applied the grease that lubricates the sensor's seal.
After that the ABS behaved itself.
Phil
acf6
Jun 2, 2012 01:11 PM
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
Firefighter 1406
May 1, 2011 09:55 PM
bwalker5
Jun 14, 2003 04:43 PM
