ABS light on
Old May 14, 2003 | 11:43 AM
bwalker5's Avatar
bwalker5
ABS light on
Anybody had an ABS light come on?
No apparent problem. Checked the obvious, fluid, wires, fuse....
Seems all is ok...
I checked the OBDII code reader and nothing was set.
This one may not get caught by it.... Not sure...
I was parking along a curb moving forward and when I went to stop to back up, the brake pedal "shuddered". Didn't seem like a problem, just odd. Light came on about 20 seconds later...
Blake
Old May 15, 2003 | 04:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
ABS light on
Has it gone back off or is it still lit?
Old May 15, 2003 | 10:25 PM
bwalker5's Avatar
bwalker5
ABS light on
Still on...
It doesn't come on until I step on the brakes. Once its on it stays on until you turn off the ignition.
Brakes work fine and yes, they will lock up...
I feels like it actually stops faster without the ABS.
Of course in the rain that will be a different story!!!
I will spend time on it this weekend.
This is problem #2 in 63K miles!!!! Not bad....
Blake
Old May 18, 2003 | 09:52 PM
bwalker5's Avatar
bwalker5
ABS light on
Checked everything really well. Only thing I found was the back brake linings had about 1/16th " left before the center groove was gone. They got replaced today. Truck goes in next week.
Old May 22, 2003 | 06:21 PM
bwalker5's Avatar
bwalker5
ABS light on
Failure was "ABS differential sensor".
No warranty....
Oh well, it's fixed...
Would have been nice to have a reader that could have read the code. I'm sure it took about 20mins to replace......
Old Jun 11, 2003 | 10:04 PM
hermiebmw's Avatar
hermiebmw
ABS light on
where exactly was the sensor located??
I got the same problem
thanks for any help
Brian
Old Jun 11, 2003 | 10:17 PM
bwalker5's Avatar
bwalker5
ABS light on
This rear sensor is mounted near the top, front of the rear diff. (it reads the ring gear).
The sensor is a ~$15-$20 part and takes five minutes to change.
I would suggest finding an Auto store or shop that can read the ABS codes. These code readers are much more expensive than the standard OBDII code readers (they don't read this error)so be sure they have the specific "ABS/Airbag" type.
The other two sensors are mounted on the front knuckles near the rotors.
I've also heard that the speedo acts funny when the diff sensor goes out but mine had no symptoms.
Also, check your Fuse!!!!
My local Ford Truck dealer charged me 2hrs labor to diagnose/fix so be sure they give you an accurate quote.(said they had to do a "pin" test because the writer wrote it was an "intermittent"problem!!!)
GoodLuck!!!
B
Old Jun 13, 2003 | 11:40 AM
TERMN8R's Avatar
TERMN8R
ABS light on
Just fyi, one of the more common reasons for a differential sensor failure is metal shavings on the magnetic pickup of the sensor. (I would think that cleaning the sensor would fix the problem, but you know dealers...). This is not unusual, but if you have the $$$, you may want to change rear end oil, and give everything a look. Dodge had a big recall on early Rams with ABS because of this.
Old Jun 13, 2003 | 11:04 PM
bwalker5's Avatar
bwalker5
ABS light on
Yup, you are correct!!!
The dealer actually told me about this problem.
They said I did not have any metal shavings though....
Shavings are the first thing they look for......
B
Old Jun 14, 2003 | 04:43 PM
hermiebmw's Avatar
hermiebmw
ABS light on
pulled sensor out and cleaned some shavings off. Drained gear lube cleaned pumpkin and put in the new 75 140 senthetic (11.99 a qrt wow!!) put sensor back and SO FAR SO GOOD!!! light stayed off!!!
Thanks
Brian
ogarcia434
May 22, 2016 08:33 AM
autumnwyatt12
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 4, 2014 08:42 PM
kjester
15
Mar 17, 2011 02:31 PM
bdp155
Modular V8 (4.6L, 5.4L)
Jan 12, 2011 03:27 PM
nocal
Jun 13, 2004 06:48 PM
