How Inefficient is the 7.3 Exhaust System?
I understand that the up pipes come directly off the exhaust manifolds from both banks of the engine feeding directly into the back of the turbo. In other words all of the exhaust gases from the engine must run through the turbo first.
Then the exhaust gases get routed through either the wheel of the turbo and/or through the downpipe which then allows the gases to exit the engine through the remainder of the usual muffler/exhaust system.
If I have this all right, then it seems to me that the exhaust flow from the cylinder heads is quite restricted at least until it passes through the downpipe. Does the changing of the up pipes help reduce this restrictive flow?
Does the use of a different turbo (perhaps with a bigger housing) assist in a better flowing exhaust process?
I know that having a bigger downpipe (4" versus the stock 3.5") will help and then of course either a 4" or 5" system all the way to the tailpipe.
The reason I ask is that I have had quite a few cars over the years and they all have been helped with aftermarket exhaust system especially when it comes to headers. On this forum there is very little discussion about headers for the 7.3 although they do exist.
Based upon my thinking above, it probably makes very little sense to change the exhaust manifolds to headers because the flow pattern is going to remain the same in order for the turbo to do its work.
I appreciate your comments. Again forgive my ignorance; I am trying to learn about this engine. Have already benefitted from this forum by changing to the proper oil, changing the fuel filter, going to biodiesel (B5), etc. Thanks
Once you knock out those two, the third step in the upgrade process would be a turbo. Enlarging the various housings will flow more air, but will also change spool up times. Without going into tons of detail, you need to set your turbo for what you want to do. A quick spooling turbo will get you quick starts, but may not build as much power in the upper RPM ranges. A slower spooling, but higher volume turbo will start like a snail and be supper laggy, but when you finally get rolling it will pull like a son of a gun. These are good for dedicated tow rigs.
By this time, your system, is changed enough that if you haven't already done it, you need a tuner to help your computer manage the increased capacity. A next step might be larger flowing injectors and a larger flowing intercooler.
To correct my self, the TRUE first step should be a good set of guages. Pyro, Tranny temp, and boost pressure.
The thing with diesels is modding is a visious cycle and once you catch the bug, your hooked and you keep uprgrading and upgrading and upgrading and............................................... ...................................
PSD Exhaust Systems...
https://www.ford-trucks.com/forums/672425-psd-exhaust-systems.html
Some interesting facts about HP...
https://www.ford-trucks.com/forums/669256-some-interesting-facts-about-hp.html#post5290668
On the one below, start at post #24 about how a turbo works as a "heat engine"!
I want to develop an idea i had for a diesel engine...
https://www.ford-trucks.com/forums/667504-i-want-to-develop-an-idea-i-had-for-a-diesel-engine-2.html
Estimating Your Maximum RWHP From 65-75 MPH WOT Acceleration Runs
https://www.ford-trucks.com/forums/667554-estimating-your-maximum-rwhp-from-65-75-mph-wot-acceleration-runs.html
A Quick Way To Estimate Your Dyno Results...
https://www.ford-trucks.com/forums/666835-a-quick-way-to-estimate-your-dyno-results.html#post5265024
What's The Net Volumetric Efficiency, VE (%), For A 7.3L PSD?
https://www.ford-trucks.com/forums/666686-whats-the-net-volumetric-efficiency-ve-for-a-7-3l-psd.html#post5267145
Turbo Surge, Turbonetics T61, GTP38R, & GT38 w/ 99.5 & Early 99 Wheels.
https://www.ford-trucks.com/forums/664991-turbo-surge-turbonetics-t61-gtp38r-and-gt38-w-99-5-and-early-99-wheels.html
Analysis Of Tenn's 6637 Restriction Data.
https://www.ford-trucks.com/forums/660609-analysis-of-tenns-6637-restriction-data.html
Equal MAF (lb/min) Does NOT Yield Equal HP!!!
https://www.ford-trucks.com/forums/659040-equal-maf-lb-min-does-not-yield-equal-hp.html#post5194401
When You Apply The Throttle, "The Tail Wags The Dog"!
https://www.ford-trucks.com/forums/658658-when-you-apply-the-throttle-the-tail-wags-the-dog.html
Engine performance vs increases in air filter inlet temp.
https://www.ford-trucks.com/forums/655390-engine-performance-vs-increases-in-air-filter-inlet-temp.html
MAF & RWHP With & Without An Intercooler!
https://www.ford-trucks.com/forums/654024-maf-and-rwhp-with-and-without-an-intercooler.html#post5152552
High Altitude Effects, Part 1 Cooling System (1 of 2)
https://www.ford-trucks.com/forums/653632-high-altitude-effects-part-1-cooling-system-1-of-2-a.html#post5157106
The Genedad 2 appears to be a success!
https://www.ford-trucks.com/forums/652772-the-genedad-2-appears-to-be-a-success.html
My rambling contribution to Tenn's CFM measurement project! (Part 1 of 2)
https://www.ford-trucks.com/forums/648181-my-rambling-contribution-to-tenns-cfm-measurement-project-part-1-of-2-a.html#post5084729
Drag Model Dissected... Need inputs to evaluate the pieces!
https://www.ford-trucks.com/forums/647127-drag-model-dissected-need-inputs-to-evaluate-the-pieces.html#post5073494
Getting ready to do some 6637 testing.
https://www.ford-trucks.com/forums/645117-getting-ready-to-do-some-6637-testing.html
A 340 RWHP F-350 vs an 800 HP Jet Powered Version... Who wins?
https://www.ford-trucks.com/forums/645343-a-340-rwhp-f-350-vs-an-800-hp-jet-powered-version-who-wins.html
Is this mod a first for a PSD pickup, and how do I analyze it?
https://www.ford-trucks.com/forums/644954-is-this-mod-a-first-for-a-psd-pickup-and-how-do-i-analyze-it.html
My Zoodad gave birth to a "Genedad"... comments welcomed!
https://www.ford-trucks.com/forums/642354-my-zoodad-gave-birth-to-a-genedad-comments-welcomed.html
Drag Race Analysis... An Interesting Story!
https://www.ford-trucks.com/forums/634460-drag-race-analysis-an-interesting-story.html#post4952627
I want 600 hp!
https://www.ford-trucks.com/forums/631407-i-want-600-hp.html
Torque Converters & Diesel Engine Breaking!
https://www.ford-trucks.com/forums/629052-torque-converters-and-diesel-engine-breaking-2.html#post4898894
HP & Torque... the REST of the story!
https://www.ford-trucks.com/forums/627653-hp-and-torque-the-rest-of-the-story.html#post4887611
I will take you up on your offer gladly. I am leaving for Australia on 11/30 to get married and won't be back until 12/27 but it sounds as though you will still be in Vegas.
WOW, I did not expect this amount of material but I will take a look at it all. I am not a mechanic by profession but I really am a gearhead who wants to know how things work to their best mechanically. I love performance but I really want to concentrate on making my F350 dually a very decent and more capable tow-rig for my 10k (loaded with 2 fine animals) living quarter horse trailer.
On my way to read. Thanks again. Ulrich
I will take you up on your offer gladly. I am leaving for Australia on 11/30 to get married and won't be back until 12/27 but it sounds as though you will still be in Vegas. Ulrich
BTW, if you've got nothing better to do during your honeymoon, check the local phone directories for a Joe Swartz, he's a High School buddy of mine, age 65, who moved to Australia years ago to get married, but unlike you, he never returned! I know he got divorced and was still there in 1990 and living at...
Joe Swartz
35 Rutledge St
Bungendore NSW 2621
I haven't got a clue where he is now, but If by chance there's only one name like that in the book, and it's a local call, tell him that Gene Kempe says hi, and find out how I can get in touch with him.
Have a safe trip, and I'll see you when you return. Bring your wife when you come to visit, she can go shopping with mine at a huge maul that's a short walk from the RV park, and we can drink beer and talk trucks!
I want 600 hp!
