Well, apparantly everyone else is watching football too or something. I don't live in the coldest place but have found that it does take a long time to warm up the engine if I just start to drive. The cooling system in the stock truck is very efficient and when driving down the road in the cold it can take a bit.
EDIT: BTW, a lot of folks have gone to the 203* thermostat for this very reason. Oh, and I do use a piece of cardboard that covers the entire grill this time of year for warmup. Then just set aside. You could conceivably block off about 1/2 of the radiator this time of year and simply drive it that way.
Alright, one more question, with all I have done, the motor temps don't seem to come up very well. Not sure if it's the things I have done or the 20deg weather we are getting, but I would think the thermostat would dictate runningt temp. Do I need to partially block the radiator? We took a 1/2 drive to the movies tonight and barely got to the line above the 'C', the needle stayed just under there. Any suggestions?
Definetley....your thermostat is stuck open and will not let your truck warm up.
This happened to me last year...couldn't get warm inside the truck and noticed temp gauge was not coming up as usual. Thought it was just the cold weather.
Anyway T stat had part of it's rubber that came off and lodged it to stay open.
Replaced with a new one and all was back to normal.
By the way....When replacing the T-Stat....also replace the T-Stat housing and O-Ring....If you don't....It WILL leak...I know this from more than one Powerstroker. Otherwise you will be redoing it to stop the leak.
Two things, first, that wheel looks kinda rough but we have seen far worse here. More on this later. I thought the WW could be installed without turbo removal???
You are correct....The WW can be installed without Turbo Removal. I've done it myself......about a hundred thousand miles ago.....and I did not bother to have it balanced....still going good.
OK, Thanks guys. So do I need to goto Ford for the housing then?
Do you think it would've been easier to remove the turbo to replace the wheel? All the right-ups say to remove it, so what's the advantage or disadvantage of doing so?
if you get that..might as well get the 203 stat to0..it bring the N.O.T up to where IH built the 7.3 to run..if you get the t stat from dealer or parts store..make damn sure it is the same as you took out..there is 2 differnt onse (short stem and long stem) and the wrong one will cook the back side of the block..read the link for the 203 to understand what i am saying http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=186
i took my turbo off cause i was up grading it any how...its hard to lay under the hood as it is..a couple of bolts are hard to get to with turbo on..dont take long to remove the turbo..you should get new orings for the turbo to pedistal and for the pedistal to block if you take it off ..you can re used the old ones..but for a few bucks its well worth it to just do the new onse now..
not sure on that..i do not know any one running that..i will say Bob is a very good guy..very honest and trust worthy..he has stoped me from buying things from him just cause i really didnt need it..i think if he thought you did not need it..he would tell you..just tell him your a member of FTE...and yes..a boost and EGT gauge is always best with mods...
Thanks Ron, I'll give them a call.
I guess the way I'm reading the ad on that actuator is, it needs to be adjusted at install.
thats what it sounds like..it should make it spool just like having the red line unhooked..but open at 25 psi(or where ever you have it set) to save the turbo..let me know what you find out...
Well, I spent a buncha money! I bought my 3 gauges, a-pillar pod, paint, 203 Tstat, Billet Tstat housing and WG actuator. OUCH!
Funny thing, my truck has been warming up sometimes, sometimes it still doesn't warm up, which tells me the Tstat is screwing up. Is there anything I should know about the coolant? Particular brand I should replace it with or anything else I should know about the Tstat change?
It's green, so that would be just plain prestone then? Should I mix 50% water? I was just going to try to drain just enough to get the Tstat out if that's possible.
