94 powerstroke
Old Nov 22, 2007 | 09:16 PM
lilkyle_eb's Avatar
lilkyle_eb
Question 94 powerstroke
I got a 94 powerstroke that i cant get running right. The person i got it from drove it for 12 hours and no problems then when i got it I had to put new seals on the injectors but then i got no start, so i finially put a cam sensor in it then got it to start but needs a shot of starting fluid sometimes i have to keep spraying it then finally runs on its own. It has a rough idle when its cold then it keeps stalling on its own but when i put it to the floor the rpms only go to about 2500 then pauses then finially kicks in, and i have very little heat i think the thermostats bad, in the proccess on that. any comments would really help times a factor
Old Nov 22, 2007 | 10:18 PM
ono_55's Avatar
ono_55
Don't use starting fluid it is very hard on our motors. Check to see if your hpor is full of oil. You more than likly have air is the hight pressure oil system that fire the injectors.
Old Nov 22, 2007 | 10:20 PM
ono_55's Avatar
ono_55
On the no heat problem these motors won't warm up at a idle, have to get out and drive them. Mine takes about 4to 5miles to get warm.
Old Nov 23, 2007 | 02:17 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
starting fluid bad......
As stated above, check HPOP oil level
Check fuel pressure
your EBPV may be keeping you from revving up and might not be related to the no-start problem
Pretty certain it sounds like you are not getting enough fuel into the cylinders. Fuel pump, fuel filter, fuel screen all need to be verified.
And dittos in the no-heat thing as well. Een with a chip with a high idle setting and a 203* thermostat you would be lucky to have a warm heater on a cold morning.
Old Nov 23, 2007 | 07:19 AM
Action4478's Avatar
Action4478
Welcome to FTE,,,Check the glow plug system & the GPR especially... Make sure the oil is full,, wouldn't hurt to change to a lighter grade 5-10w,,,Is this for sure a PS,, 94.5 with a standard trans?...
Old Nov 23, 2007 | 08:52 AM
tjbeggs's Avatar
tjbeggs
Have your driven the truck at all since doing the injector o-rings? if not you need to go out and flog it for 20 miles or so to work the air out of the system
Old Nov 23, 2007 | 04:31 PM
lilkyle_eb's Avatar
lilkyle_eb
ive changed the fuel pump and filter and the HPOP is good, fuel pressures good and ive driven it about 20 miles after changing the injector o rings but still no luck
jonm1a1
1978 - 1996 Big Bronco
Jan 10, 2013 04:31 AM
mntlecates
1983 - 2012 Ranger & B-Series
Dec 18, 2010 12:42 AM
F150owns
Oct 15, 2006 08:15 PM
F150owns
New Member Introductions
Oct 15, 2006 06:20 PM
patrickemb
Dec 17, 2005 06:59 AM
