hard time finding fly wheel
Old Nov 20, 2007 | 10:37 PM
cmbroo1's Avatar
cmbroo1
I am having a hard time finding a used fly wheel for 78 f-150 with a 400. How hard is it to replace ring gear. And is it dependable. It seems to me to be ALOT cheaper to buy just the ring and replace it. What steps am I going to have to go through.
Old Nov 20, 2007 | 11:07 PM
masterbeavis's Avatar
masterbeavis
you can buy a remanufactured one thru your local major brand parts house for around $70 or so. OR, if you want, I can sell you one I am tired of looking at. I stopped using it because I put a 460 in. Shippnig is expensive, I would try to find it local first.
Old Nov 22, 2007 | 07:24 PM
rusty7983's Avatar
rusty7983
i've had it done before. my old starter dragged. i think the ring was like 30 or so and labor was another 30. it fixed my problem.
Old Nov 22, 2007 | 08:51 PM
Matts72's Avatar
Matts72
You can just flip the ring around, it'll work like new. Just get a torch and heat the ring up, hammer it off and flip it, get it set most of the way, heat it up and hammer it back on... hit it square, don't glance off the edge... get a big dull cold chisel if you need to.
Old Nov 22, 2007 | 09:05 PM
whalerron's Avatar
whalerron
The ring is very easy to replace. Knock the old one off with a chisel and a hammer. Work around the perimeter so that you knock if off evenly. I then put the flywheel in a freezer and the ring in my oven at 400 degrees. When the ring is hot, Lay it over the flywheel and knock it on evenly. P.S. Make sure your wife isn't home when you put the ring in the oven.....it gets kind of stink. I would be hesitant to heat the ring gear with a torch because it would be too easy to remove some of the tempering.
Old Nov 22, 2007 | 09:34 PM
Matts72's Avatar
Matts72
You don't heat it to red hot... besides I've done it many times and never had a problem...
Old Nov 22, 2007 | 10:50 PM
cmbroo1's Avatar
cmbroo1
Ill try the oven trick. I dont have a torch yet...but Christmas IS on the way.
Old Nov 22, 2007 | 11:39 PM
79f-250custom's Avatar
79f-250custom
did this with my 351M worked like a charm! just make sure the wife aint home to see u put a truck part in the oven.
Mitch
Old Nov 23, 2007 | 08:12 AM
cmbroo1's Avatar
cmbroo1
I am going from an automatic to a 4 speed so all that I have found is woreout ring gears on flywheels. And since a new flywheel is avg. 150$ and new ring gear avg 26$
Old Nov 23, 2007 | 08:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 400 flywheel is different from the 351M. The 400 uses a larger clutch disc/pressure plate.
The ring gear is still available from Ford:
D7TZ-6384-A Ford list price: $54.18 / FTE member net: $38.30
The flywheel is too...but the price is $275.00: E5TZ-6375-H
Old Nov 23, 2007 | 08:47 AM
cmbroo1's Avatar
cmbroo1
MAN, Ford parts are expensive. Thanks for the info. It probably would work best if I found an original flywheel in junkyard to put NOS ring gear on. Is the flywheel for the 400 15 and sum odd inches in dia.?
Old Nov 28, 2007 | 11:57 AM
Martineznic's Avatar
Martineznic
Talking replacement ring gear
go to lmctruck.com to find the ringear for about 20.00 bucks they also have an extensive list of other hard to find parts i have used them and find they are a little cheaper than even local parts stores
Old Nov 28, 2007 | 01:40 PM
1pump's Avatar
1pump
Any parts store should have a ring gear. I used to do these all the time when I worked in parts. We used to charge $25 to replace the ring gear, but that was a few years ago.
Old Nov 28, 2007 | 02:26 PM
Mil1ion's Avatar
Mil1ion
and a lessor quality as well for some things
OR
BETTER YET.
go to Rockauto an actual FTE sponsor that sells truck parts
http://www.rockauto.com/catalog/x,ca...,parttype,5360
Sometimes parts bought locally at parts stores is the way to go.
LMC only passes on the extra costs to others and does nothing for this web site.
Old Nov 28, 2007 | 09:06 PM
cmbroo1's Avatar
cmbroo1
Thanks Dennis. Will do. I love the site and would be happy to buy from a sponser. I would be lost on my restoration without this site.
candoo
May 8, 2014 03:29 PM
Gary K G
Mar 20, 2014 09:27 PM
1976HighBoy
Aug 26, 2011 07:46 PM
sedly
Jan 23, 2011 09:31 PM
twr71
Dec 31, 2010 04:39 PM
