1966 352 timing mark
Old May 8, 2014 | 10:18 AM
candoo's Avatar
candoo
I cannot find the timing mark on the fly wheel. Am I missing something?
Old May 8, 2014 | 10:27 AM
Shadowrider123's Avatar
Shadowrider123
I was thinking about that this morning myself.
My truck didn't have a thermostat, now that it does I need to retune the carb and adjust the timing.
Last timing change was by ear, I finally found my timing light and need to do it the correct way.
I didn't see the marks either.
Old May 8, 2014 | 11:15 AM
candoo's Avatar
candoo
Yes, I have the pointer but no index. I suppose I could time by ear and will if I have to. I am hoping to install a pertronics today and wanted to check timing.
Old May 8, 2014 | 11:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by candoo
I cannot find the timing mark on the flywheel. Am I missing something?
Timing marks located on harmonic balancer (6312 in pic), not on flywheel that you cannot see unless you have x-ray vision!
Timing pointer located on timing cover.
Old May 8, 2014 | 11:33 AM
Tedster9's Avatar
Tedster9
Use a vacuum gage, gives you a reference at least. A lot of stuff has to be right for a timing light to be useful on these older trucks after all these years. If you aren't or till you are sure a gauge works great.
Never thought I'd buy a timing light again in a million years, but as it happens one should be in a care package from Speedway, today. Ordered some timing tape too, to read what the total mechanical advance is at different RPM, but a roll of masking tape and some measurement will do exactly the same thing. China marker, yellow crayon, chalk, it helps to fill in the marks on the damper. 90 deg. marks are useful when setting valve lash. A rat tail file and a paint dab will work too for whatever marks you decide runs best.
Old May 8, 2014 | 11:38 AM
candoo's Avatar
candoo
OOps, did not mean flywheel. Yes I cannot find it on the Damper. Working on these old vehicles make me wish I had x ray vision. I will try my vac gauge and go high tech and breakout my wide band O2 sensor and display.
Old May 8, 2014 | 03:29 PM
Tedster9's Avatar
Tedster9
Make some tape, or buy it, once you find the TDC mark, at least. The damper marks are often really faint marks, draw a crayon or china marker over them and wipe it off solvent works good, but the tape works better and extends out to 60 crank degrees.
If you only have a gauge and no light advance for maximum vacuum and back off just a little and that should be good for a stock motor. Reset idle RPM and mixture. High compression engines and low octane fuel won't take too much advance on initial.
Kev1180
Large Truck
Sep 2, 2015 03:56 PM
wrreed
27
Sep 11, 2009 10:06 PM
mechanixpearl
1978 - 1996 Big Bronco
Nov 28, 2006 07:03 PM
65vamonster
Jun 25, 2004 05:15 PM
