Steering Column
Old Nov 20, 2007 | 07:46 AM
SportCustomWalt's Avatar
SportCustomWalt
Steering Column
I was wanting to know which year of truck i could use for steering column. I have a 72 with P/S but no steering column. Also how do i tell which make of P/S i have? I read some where if you had 3 bolts it was this type and if you had 4 bolts it was another type. I will get the numbers off this week end as i'm stripping the frame. Any help would be a help.
Old Nov 20, 2007 | 08:32 AM
Freightrain's Avatar
Freightrain
Someone should be able to tell you which box it is....I never could remember the differences.
I think the column lengths are different also, so you have to watch that also.
blue68f100's Avatar
blue68f100
The top of the gear box will have 4 bolts holding on the cover plate if it's a Bendix.
If Bendix which is very few, The manual steering column will work.
A saganal you need a 73-77 PS column. I think in 78 the started putting the key on the column.
There is only like 2" difference in length.
I know someone else will have something to add. Beside correcting my spelling .....
Old Nov 20, 2007 | 08:57 AM
SportCustomWalt
These are the numbers i found on unit C7AR.3A58TA / D1TR-3550-BA There are 4 bolts on where steering coupling attaches.
Old Nov 20, 2007 | 12:38 PM
Mil1ion's Avatar
Mil1ion
No , The 78/79's still had the key in the dash.
The key was moved to the column in 80 or 81
Is this a 4x4 or 4x2 truck you are asking about ?
Old Nov 20, 2007 | 04:41 PM
BobbyFord's Avatar
BobbyFord
Ford box seen below...
Old Nov 20, 2007 | 09:07 PM
SportCustomWalt
Thanks for the picture. I got these numbers off the plate with two bolts C8AR then below them are the theses 3580-A2 it looks like. It says Ford on the plate also. On the side it has C7AR.3A58TA D1TR-3550-BA
Old Nov 21, 2007 | 04:40 PM
marks69's Avatar
marks69
i just put one of these in my 71. i went with a ididit colum. figured tilt would be nice and it bolts up to the factory box really easy. if you need a pump let me know, i had to use a newer one to get the serp belt to work.
mark
mauicruza
1966 - 1977 Early Broncos
Feb 27, 2015 04:51 PM
jeddi03
WTB - Ford Trucks & other vehicles
Apr 14, 2013 06:31 AM
Big Daddy T
Sep 6, 2010 04:10 PM
78150custom
Sep 9, 2009 12:04 PM
