Sponsored by: Real Truck
edge programmer
Old Nov 19, 2007 | 08:45 PM
proudtruck's Avatar
proudtruck
edge programmer
Have a 1999 7.3 powerstroke and bought a edge evalution programmer but now my buddy tells me that it puts a lot of strain on my tranny is this true or is he selling me a hog.
Old Nov 19, 2007 | 08:56 PM
faststang94's Avatar
faststang94
its true for all chips. those trannys don't take alot of abuse unless built up
Old Nov 19, 2007 | 09:02 PM
proudtruck's Avatar
proudtruck
what would have to be done to build it up and more or less how much is the cost
Old Nov 19, 2007 | 09:07 PM
medhvac's Avatar
medhvac
no problem here yet!
Old Nov 19, 2007 | 09:09 PM
proudtruck's Avatar
proudtruck
I have the evalution programmer its always going to be on a setting is it a big hassle to always have to plug in to change settings
Old Nov 19, 2007 | 10:18 PM
dfuser's Avatar
dfuser
I have used the evolution for a long time and have not had any tranny issues. Simple approach is needed to protect the tranny:
Trans gauge
Synthetic fluis
External microfine filter
Upgraded trans cooler
a mechanical shift kit
None of these will kill your budget.
Bill
Old Nov 21, 2007 | 06:45 PM
proudtruck's Avatar
proudtruck
Trans gauge
Synthetic fluis
Bill
in which mode would you leave it on for everyday driving and this save diesel
Old Nov 21, 2007 | 07:06 PM
dfuser's Avatar
dfuser
I had it on the performance (I think that is what it was called). Basically the highest setting. I did have gauges to monitor my engine closely.
Old Dec 27, 2007 | 12:45 PM
davecarpe's Avatar
davecarpe
Thumbs up Tranny Upgrade Suggestion
I have been running and Edge Evolution for some time on Tow and had a problem with my torque converter self destructing down in North Carloina.
I had it repaired down their and the fellow that owns Tri-County transmissions was very good in explaining the issue and that the stock Torque converters don't take much and of course this one went just after the 5 year warranty ran out. Anyway, what he did was put the dual clutch torque converter from the F-550 into my Transmission (on a 2002 Excursion with 7.3 L PSD). It shifts more firmly than the old one but he said this will be fine, unless I want to get really crazy building a race truck.
I have had no problems since desite stacking an Edge Juice with Attitude on top of the Evolution. I have run it and even towed a tiny trailer on Extreme with no issues at all.
Old Dec 27, 2007 | 02:51 PM
Izzy351's Avatar
Izzy351
Easiest way to help your tranny is a mod'ed accumulator valve body or a shift kit (accomplishes the same thing), and a better cooler. For some reason, Ford put smaller coolers on the 7.3s than they did on the V10s. Go figure. You can get a real nice cooler from Bob Riley HERE, and you can get a VB from John Wood Transmission or Brian's Truck Shop. Or of you think you can handle it, put in a TransGo kit yourself. As Bill mentioned, syn fluid isn't a bad idea either because it handles the heat better, so it will last a bit longer than dino. Your choice.
However, gauges are a must when you start running tunes so you don't melt a piston or overheat the tranny. Especially towing with hot tunes. The boost gauge is good as well so you know what your engine is doing, and watch for loss of boost, etc. My $0.02...
Jgardner12
Computer Chips & Tuners
Feb 13, 2015 06:45 PM
jeem
32
May 24, 2011 04:14 PM
Rat-ler
Apr 8, 2011 07:22 AM
F-250beast
Modular V10 (6.8l)
Jan 28, 2010 12:38 PM
briggs1100
Nov 25, 2007 06:26 AM
