another oem manual hub problem
Nov 19, 2007 | 02:39 PM
99 F-250 SD. OEM hubs unlocked but ujoints locked in position. Want upgrade to Warn hubs but heard that there may be an ugly gap between hub and wheel trim cap. I have factory aluminum wheels. Any suggestions?
Nov 19, 2007 | 04:04 PM
Quote:
Originally Posted by SBastow
99 F-250 SD. OEM hubs unlocked but ujoints locked in position.....
??? Don't understand reference to u-joints.
Manual or auto hubs?
Have you checked wheel rotation against axle shaft rotation with wheel off the ground?
Nov 21, 2007 | 08:55 AM
Sorry, meant axle shafts are locked in no matter what position hubs are in. I have a manual set up.
Nov 21, 2007 | 09:49 AM
You not only need to unlock the hubs but shift into 2wd.
Nov 21, 2007 | 10:09 AM
You need to pull the hubs apart to see why they are not releasing. You may have other problems besides needing to replace the hubs.
ALso, from what I undertand, Mile Marker hubs have the gap. Warn hubs do not.
Nov 21, 2007 | 10:16 AM
I am in 2wd but hubs did not appaer to be working. Planning on swapping them out for Warn hubs. I've never had good luck with ford hubs. I've always ended up replacing them with Warn's. Atleast I don't have ESOF to contend with.
Nov 21, 2007 | 03:42 PM
Warns are cheaper then the Ford hubs too.
Dec 16, 2007 | 11:05 PM
just yank those hubs out and put the warns in,,,a real fast job. grease up the new ones. tose hubs dont always disingage until you drive a little bt.
JD BuckSavage
Nov 15, 2016 11:13 AM
rock2610d
Jun 4, 2016 08:03 AM
cityjack
Mar 21, 2016 04:41 PM
brobrad
Oct 7, 2015 02:40 PM
countryboy4_1qt
Jan 31, 2007 04:35 PM
