89 jag xj6?
Old Dec 20, 2007 | 02:04 PM
  #31
AXracer's Avatar
AXracer
I see "Vanden Plas" Jags listed fairly often. I'm not a Jag kinda guy, is that a model name? Is it different from an XJ or XJS? I tended to shy away from them since I didn't know if there was a difference in the suspension?
Old Dec 20, 2007 | 02:08 PM
  #32
f100newb's Avatar
f100newb
Not sure I just know that this one was cheap and the suspension was the right size. I believe that Vanden Plas was a moniker like Eddie Bauer Edition Explorer.
Old Dec 20, 2007 | 02:31 PM
  #33
RUSTY50F1's Avatar
RUSTY50F1
The rubber mounts on the rear of the IFS bolt to the frame and the IFS. The front Gussets on the IFS slide into the front gussets that you have to make and weld to the frame.
Old Dec 20, 2007 | 02:38 PM
  #34
Virto's Avatar
Virto
Vanden Plas was a trim level for North America.
There was a base XJ, the Vanden Plas and then a fully loaded XJ.
Vanden Plas models were first available in 1982, using the same trims levels standard on the Daimler Sovereign sister car. It featured a few more options and interior wood trim that the base model lacked.
Essentially, it's the same as the standard car but would probably cost you more to buy because of the more expensive moniker.
Old Dec 20, 2007 | 02:57 PM
  #35
AXracer's Avatar
AXracer
f100newb,
be aware there are some differences in installing the Jag IFS in the 53-56 F100 and the 48-52 F1. The F1 frame is a couple inches narrower in the front than the F100. The narrower frame is a perfect match to the Jag mount width, so you just drop the frame in place, drill a few holes and fab front mount brackets.
The wider frame of the F100 or the mount location area of the Jag crossmember must be modified slightly to accomidate the extra width. I have seen examples where the frame was stepped in at the crossmember location, sorta like a shallow C notch on it's side, and others where the crossmember was notched out wider in the mount area for the frame. I don't know that one is better/easier than the other.
The other consideration with the F100 is that for some unknown reason the center of the front wheels are not in the visual center of the fender arches, so it is common to move the front axle centerline forwards 1 - 1 1/2" to correct this anomoly.
Old Dec 29, 2007 | 09:56 AM
  #36
cmoritz's Avatar
cmoritz
f100newb, Hi from one newb to another, I live in Eldersburg,work in Ellicott City ,Acura West ,stop in sometime and introduce yourself !!,We"re too close not to compare notes. I think your on the best old truck site around for technical questions,advise ,and just some good-natured humour.Check out some of the Tech articles ,RUSTY50F1 gallery and others should give you some great ideas,Good Luck!!
jtpint
Sep 1, 2014 12:59 AM
trumph
Aug 4, 2014 08:11 PM
Oz52F1
Mar 2, 2009 07:34 AM
