Just got my Edge
yes you can.... the way the edge is set up is that you can just choose which level if you want, and all of the set points are set up for what edge thinks they should be for that level. however, if you alter things such as octane level, you can go in and change things such as timing. you can always also adjust your shift points and firmness, wide open throttle fuel, tire size, etc any time. just be sure that you make all the adjustments at the same time. you cannot go in and change just one setting at a time until you get it where you want, they must all be re-entered every time.
Originally Posted by wreedZ71
Finally got around to installing a Edge tune. All I can say is WOW!. I started on level 2 then went and bought some STP octane booster and poured that in the tank and turned it on level 3. I put the octane booster in because i had a pretty full tank of regular. DO you think that was OK to do?
Why dosent Ford make the truck like this from the factory!
Originally Posted by fordtruckman
i dont have an edge but I am seriously considering getting one (or some tuner), although i thought i read that level 1 was 87 level 2 was 89 and level 3 was 91 or higher, so if some of you guys were running the truck at level 2 and only using 87 could that damage the engine?
Originally Posted by unrulee
OK this is intersesting, but may I hijack for a moment.
Concerning the Edge programmer, will it void the factory warrenty? (Yes I've searched).
Now back to your regularly scheduled forum.
Originally Posted by JimTex
Page 4 in the manual, level 2, Tow Performance Program, 87+ octane. Any octane over 87, the timing should be increased. You can run 89 but should bump the timing up +1. The same is true if you run 93 on level 3, bump the timing +1, as it is designed for 91 octane.
but i dont have a manual since i dont have an edge...but if i get one i will now know its on page 4
thanks
OK I just noticed something both the manual in my box and the manual on the internet say level 1 is the "Trans Only" tune, yet the actual Edge screen in my truck has #1 listed as "Economy." And when you read about the Evolution on Edge site, it says there are three levels with 1 being "Trans only" but then it goes on to state there is a special Economy tune for MPG.
Im confused!! Is the Economy tune something new that just came out?
1bad67sbf
2004 - 2008 F150
04-24-2010 04:41 PM
RDavis - OKlahoma
2004 - 2008 F150
08-04-2006 10:24 AM
