Gas Sending Unit Hole
Old Nov 18, 2007 | 09:18 AM
RUSTY50F1's Avatar
RUSTY50F1
The jeep tank I got for my 50f1 has the hole for the lines on the upper curve of the tank in the middle at the back. The sending unit that came with my Auto Meter gauges shows it has to be mounted on the top of the tank (flat). The tank is used and still smells like gas. The hole is about a 2 inch circle. What would be the best way to cut the hole. To keep from having any sparks.
Old Nov 18, 2007 | 10:14 AM
havi's Avatar
havi
I'll have the Roast Duck
Maybe fill it with water and use a hole saw 2" in diameter on the end of your drill. Empty out all the water afterward, and clean out the metal shavings. Afterward, maybe apply a coating inside, slosh it around to cover everything to prevent rust? I'm guessing here, but faced with that dilemma, I guess that's what I'd do. A couple years ago, a local muscle car guy died while cutting open a used oil (or something volatile) drum...and all I can say is, better safe than sorry. Even if it means your truck doesn't run good with water in the gas for a couple miles. My 2 cents.
Old Nov 18, 2007 | 10:16 AM
Randy Jack's Avatar
Randy Jack
I haven't done this, but I would use a hole saw of the right diameter and cut the hole with the tank filled with water. I'd also use an air-driven drill, if I could, just so I didn't have to mess with an electric drill around water.
If you can do this outside, you could also displace the gas fumes with auto exhaust fumes (or any inert gas) by running a line from the tailpipe to the existing fill hole. Tape it all up as gas tight as you can after purging everything for awhile, then use the hole saw.
Basically, if there isn't sufficient oxygen in the tank, the fumes can't ignite.
(Now somebody will probably answer this and point out what an idiot I am.)
Old Nov 18, 2007 | 10:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
RJ's way with the exhaust pipe is a favorite in every discussion of this I've seen, but with the difference that you leave the car running while actually sawing (keep the exhaust flowing thru the tank) and fill as much as possible with water. If you have welding nitrogen or CO2, you can purge with them too. All involve some level of risk. Personally I'd do the exhaust trick after washing the tank out with soapy water (maybe TSP), rinse, let sit open in the sun for a couple days. My son did all that to a gas tank last week for shipping, left it out for a week. It still reeked of gas and was rejected by UPS.
A sawzall or sabre saw might be less sparky.
Old Nov 18, 2007 | 11:49 AM
Kusto's Avatar
Kusto
Makes two of us then because I've done the same thing while welding a gas tank, the only exception was that I would leave the exhaust on to continue purging while the work is being done. But with the new emissions standards these days is there still enough Co2....LOL
Old Nov 18, 2007 | 02:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I was wondering the same thing! My flathead can produce exhaust that is extremely noxious, I knew it was good for something.
Old Nov 18, 2007 | 07:07 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks fellas I think I'll fill it full of soapy water and use the air drill. And I'll run water over the hole saw as well to keep any sparks away. Thanks a bunch.
Old Nov 18, 2007 | 08:04 PM
49fordpickumup's Avatar
49fordpickumup
Fuel Tank
Over the years I've seen many people weld on fuel tanks with just water inside the tank and in an open air, area with no problems. Anything more that doesn't cause ignition is a added plus. Make sure your tank doesn't have a bladder inside, some do. If you find rust inside, the POR-15 people have a tank sealer that is good product. Have a great day,chuck
raye321
Aug 11, 2013 03:06 PM
ferguson777
Jul 25, 2005 11:44 PM
rdw516
Mar 26, 2005 03:10 PM
cigarxtc
Garage & Workshop
Dec 24, 2002 06:08 PM
