Bare Metal Protection (Newbie)
Originally Posted by blue68f100
You have the advantage, I'm on disability due to nerve damage in my back. So I'm only able to work 2-3 hrs at a time. I have purchased some small HVLP guns to prevent wasting so much paint. Currently I'm working on the interior, ready for a second coat of 2K primer. Glass out of the cab, so I have to cover it with a tarp. I'm not to far off for having the outside of the bed ready too. Been working on pulling a dent from the passenger side door. In the most part, the sheet metal was straight on this truck. Just a few dents from from being on a farm for 30 yrs. These old trucks have meat in them so it takes a little more time to pull out the dents. The dent I had was in the lower door panel (trim area), a little harder to get pulled out. I have it with in a 1/4" now, so it want be to much longer, started 2"+. I have been using a stud welder and slide hammer.
Luckily in TX we don't have/or get very much cold weather. Like we have been in the 75-80F for the last couple of days. Suppose to cool of for turkey day.
If I recall your closer to my dad than me. He live in Pittsburg, TX.
I have epoxy primers as well as 2K primer. I was just interested in a product that I could use while I'm getting other parts ready. I don't mind spraying , it's the clean up afterwards, that's takes all the time.
I looked for access to the lower part of the door, it was not there. That was my first choice. I even though about taking the lower skin off to straighten it, then weld it back in. At the time I decided that was to much work. The skin on this door is ~1/16" thick. Most of the dentless repair tools were design for bear can panels. I have enough metal in this one door to make a complete car by today standards. If the dent was 5" higher I would have had inside access and it may have missed the roll. If you look at a 57-72 door panel there is a roll ~4" from the bottom.
My dent started about 12" from the front and progressively got deeper, with the max 4" from the end. I did this on a tree stump that my dad had cut down and left it 12"-14" above the ground. I did not see it, it was pouring down rain at the time it happen so I did not hear anything.
I had dents in strange places on this PU. Being on a farm for 30 yrs, it gets hit from all directions. Top tight of the cab, where a tree fell on it. Just to the left of the right headlight on the hood, where it rolled into a tree. Just to name a few.
The bed on my 79 has been stripped to bare metal for 6 years with no problems except for the spots my fingers have touched, my truck is inside a dry garage.
I am not an expert painter but would hesitate about using epoxy primer since it is tough to sand, I will use it if I am within 24-48 hours of laying paint.
I have used etch primer to cover the bare metal on the cab and fenders and seems to get stronger with age if part is not ready for paint anytime soon. I know after a light sanding I can lay the epoxy down, paint and clear soon after.
