Seized front caliper
Old Apr 29, 2002 | 10:12 AM
Stephens's Avatar
Stephens
I've always heard that you should flush out your brake fluid every 100K miles or so. Now I know why, my front disc brake caliper seized this weekend. When I took it all off the caliper was full of some crappy fluid. I made the mistake of trying to rebuild it myself instead of buying a rebuilt one (I did that for the other side). Getting the new dust shield and piston back in is a bi---. Also the rubber brake line mounts real funny on the A frame wall with goofy clips (that was another lesson learned). Morale -- flush your lines out.
Old Apr 29, 2002 | 10:34 AM
DrFord's Avatar
DrFord
mine did the same thing. My front one locked up on me and caused some pretty good damage. I had a trailer behind me when it happened and I was forced to drive about 20 miles with it locked up. it warped my rotor,burnt my bearing,and got so hot that it melted the plastic on my manual locking hubs. I too had never flushed my Fluid.
Oh well live and learn I guess
Old May 1, 2002 | 11:57 AM
Stephens's Avatar
Stephens
We sometimes forget about the simple things, that aren't so simple when you end up stuck out on the highway. Fortunately I was close to home. I think I got through with rotor Ok but the pad is unevenly worn and like yours it was sizzling hot.
Old May 1, 2002 | 04:40 PM
Vampiro's Avatar
Vampiro
my caliper is starting to seize up. i don't know if this is good or not but i took the tire off and gently moved the rubber boot back and sprayed a little wd-40 in there to losen it up. it seems to work for a while but then it starts again. when the weather warms up i will be repacing it
Old May 2, 2002 | 02:43 PM
Stephens's Avatar
Stephens
Do it now Joe. Like Dr. Ford when it goes out, its just another one of the problems that creates bigger problems. I got off kinda easy. My rebuilt caliper was 15.90, brake line was $27. Add the $$ for a rotor and bearings and being stuck on the road and it could be rough.
Old May 2, 2002 | 06:51 PM
DrFord's Avatar
DrFord
the_auto_tech
Jan 20, 2015 01:27 PM
lilrams09
6.4L Power Stroke Diesel
Jul 1, 2014 04:34 PM
tonefordays
Apr 5, 2014 03:04 PM
ilo9
Feb 25, 2010 12:42 AM
resq302
2004 - 2008 F150
Jun 23, 2008 09:49 AM
