spout connector location
Old May 1, 2002 | 08:32 PM
shotgun's Avatar
shotgun
My truck is a 96 F150. I am not sure of the location of the spout connector. Just below the coil is a grey plug with a wire going in each side. My hazy Hanes manual talks about vehicles equipped with TFI-IV ignition systems. "Vehicles with a double wire spout connector incorporate a special shorting bar into the connector. Remove the shorting bar to disable ignition advance".
I believe the TFI is mounted on the drivers side inner fender just forward of the firewall. I have located a plug that fits the description of the shorting plug. Would this be my spout or is it the one below the coil???
Thanks for any clarification.
Chris
Old May 2, 2002 | 06:37 PM
Wilber15's Avatar
Wilber15
If it ain't broke.....change stuff till it is!
I believe it is just off of the distributor. There should be a bundle of wires running off the dist. that comes to an end, with a little cap on the end. thats the spout connector. pull it. at least that's where my 302 has it...haha. maybe the I6 isn't the same. but worth checkin....
Old May 2, 2002 | 06:51 PM
DrFord's Avatar
DrFord
the spout on the 300 is in the same place
Old May 3, 2002 | 01:31 AM
charlez's Avatar
charlez
reamer
Jan 19, 2014 02:06 PM
busabusa
Sep 11, 2006 07:59 PM
Kikwear
1978 - 1996 Big Bronco
Oct 26, 2003 07:18 PM
vintagerider53
Aug 29, 2002 02:34 PM
