Finding the spout
Old Sep 9, 2006 | 06:51 PM
busabusa's Avatar
busabusa
Finding the spout
It says in the Haynes book "trucks with the double spout connector incorporate a special shorting bar remove shorting bar? I believe the two red wire plug end with the grey square cap is the spout, it is by the ecm. Question is do I remove that grey cap? Is that the shorting bar?
Old Sep 9, 2006 | 07:54 PM
quicklook2's Avatar
quicklook2
just remove the grey cap then time engine.
make sure you replace it.
Old Sep 10, 2006 | 11:51 AM
EPNCSU2006's Avatar
EPNCSU2006
The SPOUT connector will be near the TFI ignition module. On older trucks they were mounted on the distributor; on 92-up trucks they were mounted on the drivers side fender. If you are unsure of what you have found, pull it, and verify with the timing light that the timing doesn't change when you rev the engine.
Old Sep 10, 2006 | 06:33 PM
busabusa's Avatar
busabusa
Can't seem to get it off by hand, Is it ok to pull it off with a pair of pliers? Don't want to ruin anything.
Old Sep 11, 2006 | 07:59 PM
mississauga's Avatar
mississauga
Be carefull . If you crush it it may not be good any more. Try some silicon spray down the edges and see if that works to free it up.
jemini
25
Jan 23, 2008 06:05 PM
javi2001
13
Jun 18, 2005 04:55 PM
Boldt
19
Jan 8, 2003 11:51 AM
shotgun
May 3, 2002 01:31 AM
