this morning when i turned on my truck, i pulled the running lighs on. When i did that, they started to flicker. I shut them off and pulled them back on a few different times and they did the same thing, each time they flickered a few times and then stayed on... when the engine came down to low idle it seemed fine, i could put the lights off and turn them back on with no flickering... has anyone ever had this happen? Im not too sure what it is, i dont think any wires are loose, i havent messed with anywires lately either
Loose ground or hot?
Even broken fuse (not blown), I had a fuse on my Kawasaki KLR that somehow broke in the middle, so sometimes I had lights, sometimes I didn't.
I know on the older mustang 1 of the main power wires was too small a guage and the wire would burn up and kill the multifunction. The headlight switch isnt too bad to change, I think i had a harder time to get the **** off then the switch out. LOL
I was wondering if my HID's had anything to do with it, but i dont know why it would. Its only the amber lights and dash lights that flicker, the headlights do not flicker
